Low Mile Rebuilt 67 425 C heads
Old Dec 14, 2012 | 04:11 PM
f-85's Avatar
Low Mile Rebuilt 1967 Oldsmobile 425 Engine. I just pulled out of a running 1967 Olds 98. I have all receipts from the build Totaling over $4000 (not all receipts found) Engine was built at LAM Engines in Kenosha,wi. Engine has less then 20,000 miles since rebuilt. Everything is either rebuilt or new.
1967 Olds 425 engine
D block 389244 D
C Heads R186687 stamped on head
5/65 date on block
Here is all the parts for it Everything is New when built
Edelbrock Performer Intake
Edelbrock 750 carb (1407)
GM HEI Distributor
Accel HEI Super Coil, Cap, and Super Stock Wires
Comp Cams XE262H cam (.475/.480 220/224 @.50)
Comp Cam Lifters
Comp Cam Springs
Exhaust Guides
Exhaust Seats (hardened)
Rings Bearings (main, rod, cam)
L-2213 .040 over pistons (9:1 compression)
Intake Valves
Pushrods
Spring Shims
Rockers
Valve Seals, keepers, locks, spring shims
Freeze Plugs
Double Roller Timing Set
Oil Pump
Fuel Pump
Water Pump
Gaskets
Work that was done
Clean and check block, heads, and crank
Bore and hone .040 over
Polish Crank
Line Hone
Resurface Heads
Install Seats
Install Guides
Recondition rods and install pistons
Valve job, and set up heads
Assemble motor
Engine runs great! No smoke or noises. Good oil pressure and dosent run hot. Fresh coat of paint, ready to drop in and go! Your not gonna find a better used Olds BB anywhere! Also have all receipts for the build. I did a comp cams desktop dyno and it says it makes 333HP and 515TQ. The cam is mild with a slight lope. Can be put in a hotrod or cruiser. $1400 FIRM Email or call six30 885 11o1 Josh Here is the clip of it running on my run stand.
Old Dec 14, 2012 | 06:06 PM
Jaybird's Avatar
This engine looks very nice. The video was good too. Where were you six months ago?
This thing should sell quickly.
Good luck!
What are you replacing it with now?
Old Dec 15, 2012 | 08:57 AM
f-85's Avatar
Yeah its a great motor thanks! It came out of a 67 98 i parted out. Nicest thing about the car. Came with alot of receipts with the car. I have most of the receipts from the build on it. Minus intake, carb, distributor, wires, plugs stuff like that.
Old Dec 20, 2012 | 11:07 AM
f-85's Avatar
sold
76cutlass455
Mar 9, 2012 03:27 PM
Rickman48
Feb 8, 2012 03:47 AM
j_link
Aug 18, 2011 03:13 PM
Blown455
May 30, 2011 12:45 AM
Terrifying Toronado
Oct 18, 2005 12:15 AM
