1968 455 Olds 455 performance motor
Old February 15th, 2011, 04:22 PM
dp442's Avatar
Oldsmobile 455 1968 Performance Engine. Over 610 H/P. Built by Jack Merkel Racing in New Jersey. It has all the bells and whistles. Mondello pulleys, brackets, chrome Altenator, a/c compressor, power steering pump. Edelbrock aluminum heads, edelbrock torker manifold, aed carb 1000 cfm 7 quart canton oil pan. This engine has over 13,000 invested. It was ran at Jack Merkels shop and was crated up and sent to Fl a year ago. I never put in the car....sold it.
Jack Merkel Performance Engines
25 Walnut Ave.
Clark, NJ 07066
(732) 388-7088
www.merkelengines.com
Oldsmobile 455 Engine build-up
Block preparation:
Engine block hot tanked and new brass core plugs/ Federal Mogul cam bearings (1234M) installed. The block was bored +.030” on our precision boring stand. All head and main bolt holes are tapped. The block is then torque-plate honed; honing process is performed in 3 steps; piston to wall clearance held at .006”. ARP main studs (185-5401) installed.
Rotating assembly preparation:
Diamond Racing Products light weight custom forged pistons (2618 material) installed. Speed Pro “Plasma” moly piston rings (R10375-30) installed on pistons, as are Federal Mogul aluminum alloy main bearings (4294M-10), fully grooved; feed hole enlarged to 17/64”. Federal Mogul HD connecting rod bearings (8-3345P-10) and cam bearings installed (all bearing clearances held around .0025”). Competition Cams HD .250” double roller timing set (3113). Competition Cams hydraulic camshaft installed (custom grind: intake lift .584”/ exhaust lift .579”, intake duration at .050” 248/ exhaust duration at .050” 253, 114 degree lobe separation); cam degreed-in to cam card. ARP connecting rod bolts installed (185-6001), connecting rod caps relieved for ARP bolts, rods are then reconditioned and balanced. Crankshaft is hot tanked and precision ground .010”/.010”. The rotating assembly is precision balanced with damper and flex plate installed.
Components to complete short block:
Speed Pro high volume, HD oil pump (224-41203V) installed with high volume, bolt-on pick-up (15-503) and 7 quart oil pan (15-502) from Canton. Two piece Fel Pro rear main seal (BS40032; 460 Ford) installed. Johnson/ Hylift hydraulic lifters (A-951) installed. Fel Pro engine gasket set utilized in assembly of engine (Sealed Power engine set: 260-1008, Cometic intake set: C5813-060).
Cylinder Head preparation:
Edelbrock Performer RPM cylinder heads (60529) are machined w/4 angle valve seats and fitted with Manley custom “Race Master” stainless steel intake (2.150”) and “Race Master” custom exhaust valves (1.710”) installed. Valves undercut to enhance airflow.
The heads receive “bowl and chamber” porting. This port work includes intake bowl porting, which includes dropping the short side radius and dropping the port floor. The exhaust bowl receives similar port work. The far side of the combustion chamber is relieved to unshroud the intake valve; chamber then polished. The cylinder heads are then milled .030” (71cc chamber results in 11:1 c/r)) then assembled with Teflon seals (Manley 24037). New HD valve springs (Comp Cam dual springs 995-16), keepers (Comp Cams 10 degree 611-16), retainers (Comp Cams 740-16) installed. The cylinder heads are installed using ARP head bolts (180-3600). The valvetrain is completed with Manley 3/8” x 9.800” (25980-16), Harland Sharp roller rocker arms (6005). Edelbrock Torker intake manifold (2730) and valve covers (4485) installed.
An AED 1000 HO carburetor installed. Performance Distributor’s HEI distributor, “live wire” set and wire looms; distributor “degreed-in” for 22 degrees in by 3000RPM plus 14 degrees initial resulting in 36 degrees total advance (not including vacuum advance). AC Delco high torque starter included. Miscellaneous ARP fasteners included, including the valve covers, intake manifold, carburetor mounting studs, water pump and timing cover.
$13,000 invested......$7000
dpittz@knology.net
dp442 is offline
amphicar770
August 15th, 2015 07:13 AM
GoodOldsGuy
December 13th, 2013 12:10 AM
pav8427
November 1st, 2013 04:15 PM
65B01Delta
April 22nd, 2013 11:31 PM
wmachine
December 30th, 2009 05:55 AM
Quick Reply: 1968 455 Olds 455 performance motor
