hard top to convert frame
I looked in several manuals and couldn't find if a convert frame will bolt to a hardtop body. apples to apples as far as year both are same year and brand
be it a olds to olds or pontiac to pontiac buick to buick?
Yes, as far as A-bodies go, a vert frame is the same as a 2 door frame of the same year, the vert frame just has boxing sections welded into both sides to make the frame more rigid for a vert because the lack of strength with no metal roof. Hardtop frames are much easier and cheaper, why would you want to put a vert frame under a hardtop as it is redundant.
I have installed convertible frames into a few of the cars that I have owned,for that reason,to help stiffen it up.
Pontiac actually offered the option for the GTO,called the heavy duty frame,but it was simply a boxed frame(convertible),under a hardtop.
Pic of Monte boxed frame:
I advertised one last winter that was pretty nice,but had some light pitting in some areas.I had it blasted,epoxy-primed,and urethane coated. I listed it for $1500.00,and it sold the first day.I've seen them go for less,but I've seen them go for more.
Hi, I just signed up yesterday. I was wondering if boxing a hardtop frame is worth it for a street car? Mild 455, I'd like to get a 5speed and posi. I'd rather have a handler, but a pass down the 1/4 is fun too. I only ask because I have my frame off, ready for paint. Should I attempt this while apart, or is it overkill and not a wise use of time?
The convertible frame is not simply boxed with flat plates like a street rod frame. The boxing sections are formed "C" sections that are varying width and taper to properly fit the outer frame rails and still clear the floor. Without a donor convertible frame, this is not practical.
And sorry, but the modified frame shown under the convertible Monte above is NOT stiffer than the stock convertible frame. Whoever designed this is NOT a mechanical engineer. Removing the roof requires increasing bending and torsional stiffness. Bending stiffness comes primarily from the top and bottom flanges of the frame rail, not the sides. Torsional stiffness comes from making the channel a box, and the larger the box, the better. The photo above does neither (but it DOES significantly increase stiffness from a side impact - so long as the impact is at the frame rail).
http://www.tntraceshop.com/photogall...s/180300-2.jpg I have also seen welded supports to the upper control arms also not finding them easy
When I install the convertible boxed sections,I also add some gussets & other bracing to other parts of the rear frame,to help stiffen it up as well.It's much easier when the body is off,and you can work over it.However,you do need to have an understanding as to where the body sits,to make sure it all clears when finished.
ros6872
Jun 18, 2013 06:55 PM
oldsmobilty
Sep 27, 2012 04:26 PM
cjprm
May 19, 2011 09:17 AM
