1967 Climatic Combustion Control air cleaner-complete set up
Old Jun 30, 2024 | 09:29 PM
Dave442's Avatar
As the title references….complete with the hard to find manifold adapter. This is the 4 barrel setup…..I also have a 2 bbl air cleaner and another 4 bbl air cleaner, plus one more pipe, plus two more pie tins. Will not separate setup, the manifold heat shield is the hard part to find. $500 for the setup , plus shipping. Others priced less. PM or text 661-203-6953.
Old Jul 1, 2024 | 06:22 PM
joes_olds's Avatar
These are pretty neat, IMO. GLWS.
As a side note, the two barrel version will fit a stock manifold/carb with an HEI conversion. Note sure about the 4 barrel version.
Old Jul 1, 2024 | 07:10 PM
2blu442's Avatar
Do you know if this came off an A-body or a full sized, or Toronado? I'm wondering if the piece that goes over the exhaust pipe is different between applications. John
Old Jul 1, 2024 | 07:57 PM
Dave442's Avatar
If I remember right it was a 67 cutlass or 442. I remember spotting it in the junkyard and thinking it was cool, even though I had no use for it.BTW, in reference to the HEI conversion , I have both 2 and 4 bbl versions and the air cleaner itself is the same size, only difference is carb opening.
Old Jul 1, 2024 | 07:58 PM
Hairy Olds's Avatar
Shoveling Snow
The piping is not for a Toronado.
Dave442
May 18, 2024 08:28 AM
BeenThere
Jul 9, 2022 06:53 PM
dragline
Nov 28, 2020 11:27 AM
oldaman
Jan 6, 2020 10:36 AM
RAG
Nov 25, 2019 07:36 PM
