1967 Vista Cruiser 3:08 posi rearend
Old Jan 14, 2022 | 02:08 PM
Bob Kelso's Avatar
This a 1967 Vista cruised posi rearend , it is the o-axle with 12 bolt rear cover and the 10 bolt 3:08 ratio posi setup , the axle code is SN , it is used but turns freely and liiks good inside , i dont know how many miles are on it . Price is $ 850 picked up at my location on the Illinois - Wisconsin border , zip 60034
Old Jan 15, 2022 | 07:23 AM
Bob Kelso's Avatar
I have the brake drums for this rearend , so it is being sold with the brake drums , just not pictured
Old Mar 20, 2022 | 07:53 PM
442TUFF's Avatar
Will this fit 69 442
Hi Bob. I'm interested in this rear end. Will this bolt directly into a 1969 442 A body? If so I'll take it. Thanks. Barry
Old Mar 20, 2022 | 11:23 PM
Gerald Nickels's Avatar
YES I bolted in a 70 W-27 posi into my 64 Cutlass with 3.91 gears. Might have coil perch problems like I did but worked out ok.
Old Mar 21, 2022 | 04:33 AM
442TUFF's Avatar
I was hoping for a remove and replace without having to alter or customize spring perch. Thanks for the info.
Old Mar 21, 2022 | 05:44 AM
You should not have any coil perch problems, 67 uses pigtail ends on both sides of the springs.
Old Mar 21, 2022 | 07:15 AM
Bob Kelso's Avatar
The only thing i see is the shock mounts are off set and may require some modification to get the right angle for the shocks . I have not bolted it into a non Vista body to see if it is an issue . BOB
Old Mar 21, 2022 | 09:09 AM
442TUFF's Avatar
I appreciate your insight. I'll keep looking for an A-body replacement to keep it a simple swap. If you have one that I overlooked in the classifieds, I'd be interested .So keep me in your contact list please. Thanks. Barry
Aug 21, 2021 12:40 PM
Bob Kelso
Jan 29, 2021 02:31 PM
Bob Kelso
Dec 4, 2020 02:29 PM
Bob Kelso
Dec 29, 2019 06:24 AM
70vista
Apr 24, 2016 06:59 PM
