12 bolt housing 402227
Old Apr 25, 2021 | 05:51 PM
1970supremevert's Avatar
Hello All
Housing and backing plates with 12 bolt covers both included orange painted with drain plug , bolt at on housing at 5 o'clock position needs to be drilled out the housing has pitting store under tarp
I also have 2 - 31 spline OEM axles with with long studs, not sure of the 31 spline axles will fit in the housing
see pics I am not building any rear ends in the near future
250.00 housing
125 for the axles
I have 672 rear carrier also but was previously welded I will create another post for pics of the carrier $125.00 with gear set & with clutches
I can drop off at the shipper of your choice prices do not include shipping I am in MD
Old Apr 26, 2021 | 05:17 AM
ROCKETMAN269V's Avatar
I don't see any indication that the bearing caps were marked to indicate which side they came off of. They are not interchangeable.
Old Apr 26, 2021 | 06:04 AM
I was not aware of that
Old Apr 26, 2021 | 01:58 PM
The HD 31 spline axle shafts fit the 67-69 housing that are made for the sealed bearing and the oil seal pressed into the tube. They will not fit in the 70 housing that is made for the open bearing and seal pressed onto the shaft.
Old Apr 26, 2021 | 04:32 PM
thank you
look like it may be going to the scrap metal yard
Old Apr 28, 2021 | 06:00 PM
sale pending
BeenThere
Jun 30, 2022 05:06 AM
1970supremevert
Apr 28, 2021 06:03 PM
briane
Jul 13, 2020 03:53 PM
L4.125
Sep 10, 2019 05:20 AM
OldsAl
Mar 18, 2017 03:20 PM
