1966 425 Engine w/ B Heads $400
Old Apr 7, 2021 | 12:10 PM
RAG's Avatar
RAG
1966 425 engine casting number 389244 D, .842 dia. lifters, 45 degree camshaft. B heads with 390390 cast iron intake. High compression pistons and big valve heads off a '66 442 tri carb engine. Distributor is dated '65 off a '65 Cutlass Carb is off a 1967 Cutlass 330 engine and I was running it on another car. I have shipped engines on a pallet across the country is the last couple of years for less than $300 truck freight.
Old Apr 7, 2021 | 02:00 PM
Oldsmaniac's Avatar
That air cleaner appears to be the longer snout 4bbl one found on the 375 HP Starfire engine option.
Old Apr 7, 2021 | 02:15 PM
RAG's Avatar
RAG
The air cleaner came off a 425 in a '67 98. I don't have any 442 air cleaners.
Old Apr 7, 2021 | 03:13 PM
Andy's Avatar
I would think just the b heads with a factory T stamp are worth your asking price,
Old Apr 7, 2021 | 04:27 PM
jcdynamic88's Avatar
is this just a core for rebuild or a recently running engine? thanks
Old Apr 7, 2021 | 04:30 PM
Noodles66442's Avatar
Location?
Old Apr 7, 2021 | 06:22 PM
RAG's Avatar
RAG
The short block was a running engine, good compression, no smoke. But I removed the cam and lifters for a new engine build and reinstalled some old 425 parts. I was also running the carb. Heads need rebuilt. So rebuild the heads, buy new cam and lifters, new points, rotor and distributor cap and you have a running engine. Crank is drilled for manual and has bearing in place. If I parted it out the heads alone should be worth price, and a $200 crank shaft, $100 carb etc. I just need to get rid of stuff.
Trunk freight from Albuquerque or pick up off I-40.
Old Apr 7, 2021 | 08:59 PM
mister-twister's Avatar
PM sent
Old Apr 8, 2021 | 10:10 AM
Jerry Griffith's Avatar
Old Apr 8, 2021 | 10:12 AM
how much to ship to livonia Michigan 48152
Old Apr 8, 2021 | 01:29 PM
RAG's Avatar
RAG
$295 is cheapest by FedEx
rgreen@q.com
Old Apr 9, 2021 | 06:50 PM
Shipping
Can that be shipped to a resident and to would you except payment
Old Apr 9, 2021 | 08:26 PM
RAG's Avatar
RAG
Can only be shipped terminal to terminal. Payment by Money Order. Weighs 600 lbs. Other loose parts can be sent to residence.
Old Apr 10, 2021 | 07:42 AM
RAG's Avatar
RAG
I'm removing the "B" heads and replacing with "C" heads that need rebuilt. The tri-carb "B" heads are too rare to let go with this engine.
Old Apr 25, 2021 | 07:05 PM
RAG's Avatar
RAG
'66 425 engine
Originally Posted by rag
i'm removing the "b" heads and replacing with "c" heads that need rebuilt. The tri-carb "b" heads are too rare to let go with this engine.
sold
Old Apr 26, 2021 | 08:40 AM
Matheu's Avatar
Do you still have it? Can it be shipped to CA.? Is it a 39 degree or 45 degree cam bank angle block? let me know. I'm interested .
Old Apr 26, 2021 | 10:09 AM
RAG's Avatar
RAG
425 Engine
See previous post, engine has been sold.
craig442
Aug 3, 2024 03:36 PM
RAG
Aug 3, 2024 11:19 AM
toma1989
Mar 20, 2024 05:25 AM
Superdutch71
Mar 10, 2021 03:46 AM
oldaman
Jan 6, 2020 10:36 AM
