Speed pro camshaft
Old Apr 4, 2021 | 08:59 PM
Rca's Avatar
Rca
Speed pro camshaft
1 cs-176r new in the box. Price is 75.00 plus shipping
Old Apr 8, 2021 | 09:12 PM
64Rocket's Avatar
Do you have any spec's for this cam?
Gene
Old Apr 9, 2021 | 12:31 AM
Single pattern 232° @ 0.050, 0.474 lift.
Old Apr 9, 2021 | 04:53 AM
android 211's Avatar
Speed Pro cam
Does the cam card show the LSA?
Old Apr 9, 2021 | 05:37 AM
ROCKETMAN269V's Avatar
Brand: Sealed Power
Cam Type: Hydraulic
Exhaust Duration: 232 Deg
Exhaust Lift (Inches): .296 in.
Exhaust Valve Lift 1 (Inches): .474 in.
Intake Duration: 232 Deg
Intake Lift (Inches): .296 in.
Intake Valve Lift 1 (Inches): .474 in.
Lobe Centerline (Exhaust): 114 Deg
Lobe Centerline (Intake): 112 Deg
Lope Separation: 113 Deg
Overlap: 82 Deg
Old Apr 9, 2021 | 04:02 PM
70W-32's Avatar
Anybody know what the advertised duration is? Just curious
Old Apr 9, 2021 | 04:29 PM
Well you'd think it wouldn't be hard to find that info, but I searched the web and couldn't find the advertised duration anywhere.
Rock Auto has all the other specs as noted above, but no advertised duration:
https://www.rockauto.com/en/moreinfo...=5575836&jsn=3
edit:
RA's site above showed Alternate/OEM Part Number(s): E908P
I looked up Elgin E-908-P and found this site with a pdf catalog. E-908-P on page 9 shows the advertised duration is 308º.
https://images.carid.com/elgin/items...ct-catalog.pdf
That seems a bit short for 233º @ .050" lift.
The site below shows the same E-908-P part number with 329º advertised duration, which matches the factory Olds specs for the W-30 manual trans camshaft:
https://www.quangtungn.com/index.php?main_page=product_info&products_id=13414 5
  • Valve Lift .474/.474
  • Advertised Duration 329/329
  • Duration At .050" Lift 232/232
Old Apr 9, 2021 | 04:43 PM
Maybe manufacturers are getting away from posting "advertised" duration anymore because they know that duration @ 0.050 is much more useful information and nobody pays attention to the "advertised" number, anyway.
Old Apr 9, 2021 | 06:10 PM
70W-32's Avatar
Thanks, I had a feeling it was a W cam duplicate
v8al
Nov 19, 2020 06:11 AM
Chris6542
Apr 23, 2020 09:52 PM
Oldzman71
Apr 14, 2019 06:37 AM
beamer442
Apr 6, 2018 09:06 PM
Gary M
Feb 4, 2018 05:37 PM
