Olds 442 Starter Heat shield and brace bracket plate
Old Jan 14, 2021 | 12:50 PM
11971four4two's Avatar
MOTORHEAD
SOLD Pictures added .. scroll down Thanks
Clean original GM shield available $75 one has SOLD Thank Ye
Old Jan 16, 2021 | 03:11 PM
4SPEED67's Avatar
starter heat sheild
what years this will work for ?
Old Jan 16, 2021 | 03:51 PM
MOTORHEAD
With a look on the internet vendors show fits these years
1964 to 1972
1972 to 1977
1964 to 1977
I would think from 1964 to 1977 Oldsmobile V8 engines. I am not exactly sure which years this was installed by the factory. The starter housing either has to have a stud coming out of it Or a drilled and tapped hole to put a bolt into it. One must use a very short bolt.
This shield also has a hole for the clutch return spring on manual transmission cars
Old Mar 23, 2021 | 04:03 PM
Yellowstatue's Avatar
My '80 - '84 Regency's used that heat shield.
Old Mar 26, 2021 | 05:49 AM
MikeManer's Avatar
If it's still available I'll take it.
Old Apr 2, 2021 | 10:58 AM
MOTORHEAD
Old Feb 28, 2022 | 12:10 PM
MOTORHEAD
Pics are of the actual part you will get
I ran it through vacu blast machine and it has been peened with glass media
it is clean
Old Feb 28, 2022 | 01:43 PM
rcorrigan5's Avatar
Randy C.
The advertised bracket was installed by the assembly plants starting in model year 1970. The one used for model years 1968 and 1969 was more of a strap and less of a heat shield. However, the advertised bracket will also fit '68 and '69 model years and provide much more of a heat shield than what the original strap design did.
Randy C.
Old May 24, 2022 | 09:01 AM
MOTORHEAD
I do still have one of these , pictured , that I will sell
Old May 24, 2022 | 07:42 PM
Hello, I have a need for this one. PM incoming.
Thanks for the tip Randy.
Old May 28, 2022 | 08:15 AM
MOTORHEAD
Sold Thank You
m371961
Nov 18, 2020 04:11 AM
442crzy
Feb 5, 2020 08:01 AM
cheven
Jul 14, 2014 10:01 AM
Mike77
Feb 10, 2014 10:18 AM
pcard
Aug 20, 2013 03:53 AM
