1966 oai shroud air cleaner
Old Feb 23, 2020 | 03:29 PM
66-3X2 442's Avatar
********************************Shroud is sold********************************************** *******
I have for sale a 1966 OAI Shroud/Air Cleaner. $7,500 . I also have the complete OAI kit to install on your car. The kit includes everything needed to do the complete install. Included is the battery cables,bumper scoops and bezels,battery vent cover,all clamps and hoses etc. Included is a copy of the factory OEM installation instructions. Everything included in the kit is new reproduction parts as per OEM specs. The kit is $2,000 additional.
Contact me by email @ pchopesq@aol.com
Mike Richards
205-681-0502
Old Feb 23, 2020 | 06:37 PM
Gerald Nickels's Avatar
What number is it ?
Old Feb 23, 2020 | 06:51 PM
66SportCoupe's Avatar
Is that one hand bucked or stamped??
Old Feb 23, 2020 | 07:39 PM
66-3X2 442's Avatar
Originally Posted by Gerald Nickels
What number is it ?
It's a non numbered second design unit. Only the shrouds done by Demmer were numbered. There were shrouds numbered up to 98 or 99 but none in the 100's that's known.
Old Feb 23, 2020 | 07:40 PM
66-3X2 442's Avatar
It's a non numbered unit.
Old Feb 23, 2020 | 07:51 PM
Ok. Probably later fully stamped unit
Old Feb 23, 2020 | 08:09 PM
66-3X2 442's Avatar
Yes,that's correct. Only the Demmer built units were hand stamped and numbered. Theory has it that the GM vendor used for air cleaners did the second units.
Old Feb 23, 2020 | 08:10 PM
Funny demmer was going to send me the wooden buck for original ones
Old Feb 23, 2020 | 08:12 PM
I do know all about the original numbered units even the trac pak ones
Old Feb 24, 2020 | 05:49 AM
Run to Rund's Avatar
Then you also know that the numbered shrouds were about 1/4 inch too shallow. Paper element air cleaners don't fit and the factory had to use a press to squash the screens a bit so they would go in, to use the foam air filters. Also you can tell from the pictures at the top that there are 4 screws in front, and 4 in back. The hand-massaged early shrouds had 5 and 5.
Old Feb 24, 2020 | 05:50 AM
Correct. I had squashed foam and metal internals
Old Feb 24, 2020 | 05:57 AM
Hairy Olds's Avatar
Shoveling Snow
And where did the term Trac Pak come from?
Old Feb 24, 2020 | 05:58 AM
Curt Anderson
Old Feb 24, 2020 | 06:00 AM
He lives 25 minutes away from me here in Minnesota
Old Feb 24, 2020 | 06:04 AM
HammerMass's Avatar
At what point in history was this supposed to happen and why didn't it actually happen?
Old Feb 24, 2020 | 06:07 AM
This was going to happen in 1998. Jim Stohlman and others didn't want it around so as any effort to reproduce them could devalue real cars.
Old Feb 24, 2020 | 10:08 AM
66-3X2 442's Avatar
The best way to shorten/squash/squish/beat down etc. is to use a bead roller. When you run a bead in the middle of the screen,it shortens it, Makes for a neat clean job unlike the ones you beat down with a 2x4 and a hammer. Thanks Dad for the tutorial anyway.
Old Feb 24, 2020 | 10:11 AM
66-3X2 442's Avatar
Curt Anderson
I believe Don Henrichs also had a hand in that term.
Old Feb 24, 2020 | 10:13 AM
Oh yes! You are correct in that
Old Feb 24, 2020 | 06:02 PM
Noodles66442's Avatar
  • Unfortunately buying is not a option but just want to say how cool this is. You all need to write a book with all of this info for those of us who want to learn about these cars, for me there is nothing cooler then a 66 w-30.
Old Feb 24, 2020 | 06:36 PM
Lonnies Performance's Avatar
I remember seeing one of these about 25 years ago at Carlisle for $1200 & thought "wow is that expensive" lol...
Old Feb 24, 2020 | 07:24 PM
66-3X2 442's Avatar
Inflation. LOL. Seriously, I actually have 2 of these shrouds and have had 6 previously. I know of a sale of a shroud a few years ago that was $10K. I just hope somebody can use them for their cars.
Old Feb 24, 2020 | 08:39 PM
CRUZN 66's Avatar
Olds Fever
I purchased my 66 W30 setup, air cleaner, carbs and intake for $125 back in 1983... At the time I wasn't even aware of what I actually purchased until I started to do some research... Obviously, the seller wasn't aware as well...
Old Feb 25, 2020 | 05:56 AM
I need to get all the stuff to do my 67. I have a couple shrouds, some original but not awesome hoses, and a set of original, and a set of accurate repro ducts for the 67. Need to look through Curt's catalog again and get all the wires, clamps, hold downs, vent tubes, etc.
Old Feb 25, 2020 | 08:33 AM
66-3X2 442's Avatar
The guy I got this shroud from said he paid $25 for it. He bought it back in the 80's he said.
Old Feb 29, 2020 | 08:21 PM
66-3X2 442's Avatar
Ttt
Old Mar 7, 2020 | 07:54 PM
66-3X2 442's Avatar
ttt
Old Mar 8, 2020 | 07:28 AM
stan 65 cutlass's Avatar
Cool 😎👍
thanx for the info
droptopron
Dec 28, 2019 08:27 AM
virtualwsp
Aug 18, 2019 06:41 PM
anthonyP
Aug 3, 2018 09:23 PM
Olds luvr
Feb 8, 2010 09:05 AM
