1961 olds 394 starfire engine
Old Dec 7, 2018 | 08:49 AM
Luther99's Avatar
For Sale , 1961 394 Starfire engine , orig trans , carb , generator , chrome valve covers , red engine , flat top pistons , #23 heads , unsure of mileage, $1g Canadian obo.
Old Dec 7, 2018 | 10:36 PM
61Bat's Avatar
Curious this engine has an exhaust crossover i thought Starfire would have dual exhaust.
Old Dec 9, 2018 | 11:37 AM
Luther99's Avatar
Yes you are correct , but from all the research l've done #23 heads only came on Starfire engines in 61 , engine came out of a 61 Super 88 , doesnt look like the engine has been apart , unless early in it's life under warranty the heads were switched and its a Skyrocket engine ? ,. would like to find some carb and cam numbers to verify .
Old Dec 9, 2018 | 08:18 PM
jminor1961's Avatar
Hello
Go to the drivers of the motor there you will find a number on the head in middle of the block right under the valve cover its about 4-5 letters and has a S after the numbers if its a starfire
Old Dec 13, 2018 | 04:37 AM
Luther99's Avatar
Thanks , I've posted all the numbers on the engine forum , your the first to come up with the S after the cylinder head number which l don't have , the number is N209718 , If you are correct l have a Skyrocket engine.
dorvin
Sep 9, 2015 07:06 PM
kevin.horton
Sep 17, 2014 01:56 PM
texkiernan
Jun 12, 2013 09:04 AM
trackz man
Dec 13, 2010 12:45 PM
theoldsmobilekid
Jul 7, 2008 09:35 AM
