Oldsmobile Big Block 45 degree V8 Lunati Cam
Old Nov 19, 2017 | 02:43 PM
forstatd's Avatar
I have a brand new Lunati camshaft for Oldsmobile V8 64-67, w/45 DEGREE BLOCK Please do your homework as I know very little about this cam. See specifications for lift and duration information. Thanks for looking! Asking $100 plus shipping or pick up at my location. Zip 48917, Lansing, MI ("Oldsmobile Capital" of Michigan)
Old Nov 20, 2017 | 04:36 AM
rustyroger's Avatar
'87 Delta 88 Royale
What the pros and cons of 39 vs 45 degree lifter bank angles?.
Roger.
Old Nov 20, 2017 | 04:48 AM
forstatd's Avatar
Roger, I am not a cam expert like many folks here are. All I know is that Oldsmobile had 2 different type of big block engines, a standard 39 degree cam bank angle (CBA) and a 45 degree CBA back in the day. Camshafts do not interchange between these 2 motors. My 66 442 with a 400E motor has a 39 degree cam bank angle. There is a tremendous amount of information written about the Olds CBA.. Below is just a small excerpt taken from the Oldsmobile FAQ...
Oldsmobile engines from 1964 onward originally used a 45 degree cam bank angle (CBA) and corresponding 0.842" diameter lifters. This angle is formed by the intersection between the cam centerline and perpendicular lifter centerline. By 1968, all Olds engines were using a 39 degree CBA and corresponding 0.842" diameter lifters. In the years between, 39 degree CBAs (and corresponding 0.921" diameter lifters) were used mainly on blocks found in models with premium engines, like Toronado's, 442's and Starfires. 45 degrees was being used everywhere else. The CBA also affects the pushrod hole angle in the heads.
Old Nov 20, 2017 | 05:11 AM
rustyroger's Avatar
'87 Delta 88 Royale
Thanks. I now know much more about Oldsmobile camshafts than I did when I got up this morning .
I thought hen I first looked at your post it was referring to some oddball cylinder angle casting I'd never heard of. Lancia made narrow angle V4 engines for a long time.
Roger.
Old Nov 20, 2017 | 10:14 AM
Originally Posted by forstatd
I have a brand new Lunati camshaft for Oldsmobile V8 67-90, w/45 DEGREE BLOCK
That should be 1964-1967 as in 1968-onward all of the Olds V-8 blocks were 39º CBA - you even posted that in the info you copied for Roger.
Old Nov 20, 2017 | 06:13 PM
forstatd's Avatar
Sold!
nicks1966
Jan 1, 2013 04:51 PM
1971viking
Nov 12, 2012 02:31 PM
64Rocket
Sep 22, 2012 03:00 PM
70442rag
May 22, 2011 06:21 PM
70oldscutlass
Apr 23, 2010 08:56 AM
