Vacuum lunati cam
Old Oct 17, 2012 | 11:32 AM
1971viking's Avatar
Vacuum lunati cam
My vacuum is @10 in park and @9 in Drive. What are you guys running? Do you use a electric vacuum pump to generate additional vacuum for power brakes?
Old Oct 28, 2012 | 04:11 PM
Delmont 88 PA's Avatar
I have a Comp Cams ***** Thumpr (~300 duration and ~500 lift) and have around 13" idling in neutral.
Old Oct 28, 2012 | 04:31 PM
Qwik71442's Avatar
Full-time Taxpayer
which lunati cam do you have or what specs? I have 13-14" with a voodoo
Old Oct 29, 2012 | 06:54 AM
1971viking's Avatar
Lunati Bracket Master II Cam
Hydraulic, fair idle. Good cam for high performance street or mild bracket racing applications, has good mid range torque and horsepower.
· Advertised Duration (Int/Exh): 290/300
· Duration @ .050 (Int/Exh): 224/234
· Gross Valve Lift (Int/Exh): .496/.520
· LSA/ICL: 112/108
· Valve Lash (Int/Exh): Hyd/Hyd
· RPM Range: 2500-5500
What is your brake booster size? Mine is 9inch.
Old Oct 29, 2012 | 07:07 AM
oddball's Avatar
That vacuum is a little low for that kind of cam in a 455. I'd expect at least 14". Sure everything is tuned right and you have enough initial advance?
10" is pretty low for power brakes.
Old Oct 29, 2012 | 12:09 PM
cutlassefi's Avatar
Check the obvious, vacuum leaks etc. I'd guess it wasn't degreed in so I'd check the cam timing. Those cams are lazy enough, having late valve timing will make it worse.
Old Oct 29, 2012 | 12:49 PM
jfb's Avatar
jfb
hey dude i have a fairly large street cam and i use a vacuum can attached to aid in my vacuum needs. I would also say it is very easy to install 1 bracket 2 hoses etc.
Old Oct 29, 2012 | 01:21 PM
Qwik71442's Avatar
Full-time Taxpayer
· LSA/ICL: 112/108
I've used that cam at least 3 times and never had an issue with power brakes there has to be something wrong or it is mis-tuned. The vacuum that cam produces is not great but should be sufficient to work the power brakes.
Old Oct 29, 2012 | 02:27 PM
1971viking's Avatar
Bumped Initial timing at 14 degrees. Car runs great. Very responsive good power. Vacuum @ 11 now. I get one good pump on the brakes and then nothing.
What size booster do you have?
Old Oct 29, 2012 | 02:47 PM
Qwik71442's Avatar
Full-time Taxpayer
I've used the stock and the 9" with good results. Should need roughly 12" vacuum.
I would try to get a little more initial timing in but be careful to keep your total timing in the ballpark of 30-38 max depending on your compression and the fuel you use.
For example: I have one currently setup where it has 18 initial @ idle and 36 total by 3000rpm
What distributor do you have?
Old Oct 29, 2012 | 04:40 PM
1971viking's Avatar
http://www.summitracing.com/parts/su...ake/oldsmobile
The distributor’s
mechanical advance is 6° @ 900 RPM, 8° to 10° @ 1200 RPM and reaches a
maximum of 10° to 11°@ 1500 RPM The vacuum advance provides 10° of advance.
So that is 20 + initial?
Old Nov 12, 2012 | 01:58 PM
442rocketdave's Avatar
Try checking for vac leaks like CutlassEFI suggested I use a can of wd40 and spray around to carb and intake and check those hoses. Then check the carb then the distributor if all is well you should have 12 to 14 at idle with that cam. I have 6 different Lunati cams and I never have had a problem with vacuum. Good luck.
Old Nov 12, 2012 | 02:31 PM
cutlassefi's Avatar
True, try that first.
But this ain't really a Lunati cam. Most of these generic cams are ground by Camshaft Machine in the midwest and they sell for less than $100.00. These are done with old GM lobes and aren't anywhere near what is available today, from anybody.
bluecab
Nov 28, 2014 12:42 PM
VinMichael
Apr 6, 2014 01:38 PM
nicks1966
Jan 1, 2013 04:51 PM
64Rocket
Sep 22, 2012 03:00 PM
70oldscutlass
Apr 23, 2010 08:56 AM
