7040255 carb
Old Oct 2, 2017 | 05:15 AM
Vader's Avatar
sold
sold..
Old Oct 2, 2017 | 06:00 AM
rallyredw31's Avatar
That's a good one and I'm glad I don't need it. Same date as my car. GLWS.
Old Oct 2, 2017 | 09:55 AM
sbasinger@hotmail.com's Avatar
Who did the restoration.....it looks great!
Old Oct 2, 2017 | 10:37 AM
jensenracing77's Avatar
Just curious, What is the casting number on the base plate? It is located on the back right corner looking down at the bolt hole location. (right side looking at it from the front) Would be left side of car... It is in a circle
Old Oct 2, 2017 | 10:45 AM
scottv442's Avatar
Maintained
Looks like 705234....??
Old Oct 2, 2017 | 11:29 AM
Vader's Avatar
carb
7038294..same as used on the 256 I believe.. but I'm no expert.
7040255 on left, 7040256 on right
Old Oct 2, 2017 | 12:46 PM
Thanks, I thought that was the case also but was not sure. I am not an expert on the 255
Old Oct 2, 2017 | 11:59 PM
davebw31's Avatar
the hanger for secondary air valve metering rods shows an "N" hanger, which really is very lean above 3,800 rpm. Most real 255 carbs came with "E" hangers. Hmmmmm
Old Oct 3, 2017 | 01:11 AM
virtualwsp's Avatar
Is this the same carb that was listed on eBay couple weeks back?
eBay item number:
132278775741
Old Oct 3, 2017 | 01:45 AM
virtualwsp's Avatar
I looked at my old 7040255 W31 carb with a 0970 build date and it also has "N" hangers. The second one I had with similar early 70 build date (0900) had an "H" hangers. The 0900 carb was all original and taken off an auto W31. Hmmmmm
Old Oct 3, 2017 | 04:38 AM
Vader's Avatar
carb
Thanks Dave, I didn't notice that. I do have a proper hanger, and it has the AU rods. Although Ive seen a few with AX rods as well. Get that fixed asap.
Both 256's I have use the "G" hanger. I have an nos 256 as well, but don't want to remove the shrink/plastic top just to check the hanger. It's a service date with the later airhorn, so I'm guessing it's different.
Old Oct 3, 2017 | 06:19 AM
Both of the 0256 I had with 69 date codes had the "I" hanger and AU rods.
Old Oct 3, 2017 | 10:30 AM
Vader's Avatar
255
I changed the hanger to an E , and the rods are AU.
I heard that the hangers may have been changed anytime the carbs were flow tested or "trended" for the best performance. Any hanger which improved performance was used for that particular trend.
Eric, yes I had two other originals with an I, ad a J.
Old Oct 3, 2017 | 01:43 PM
OldsAl's Avatar
You should have 57 primary jets with no metering rods. Hey can you post a pic of the front of the carb base below the fuel filter inlet? Thx, Al
Old Oct 3, 2017 | 03:55 PM
Vader's Avatar
255
here ya go Al...
Old Oct 3, 2017 | 05:48 PM
OldsAl's Avatar
No APT. The real deal! Nice. So happy to see that. I will pass that onto a friend. Thanks Mike.
Old Oct 3, 2017 | 08:29 PM
davebw31's Avatar
OK, I checked my Rochester Engineering Secondary Air Valve Hanger Specifications Chart for Q-jets. I had made a hand written note next to the "E" hanger specs. which was "W31 #1", then next to "G, H, I hanger W31 #2". I agree on Rochester's Test Flow of all Q-jets and that they did make changes for both air/fuel flow and Emissions. Don't forget about the more strict Fed. Emissions for the 1970 Model Year Production that took effect on Jan 1st, 1970.
I just don't agree about the "N" hanger on a W31 carb. Maybe on a reg. 350 or 455. Also, on those 1970 W cars sold in Calif. that had to have the "N9" Emission Option may have had the "N" hanger. I never really got in to all the parts that made up the "N9" Option or the specs. I do know about certain aspects of the system, but not all, so I am pretty lame on that.
Old Dec 1, 2017 | 01:55 PM
Factoryhotrod's Avatar
W31 carb Mr WSP, I have a correct 7040255 carb dated 3329, if your buyer or anyone is interested. Restored, mint... $2500
is your carburetor still available? Thanks Gene. 259-228-1442
Old Dec 1, 2017 | 08:20 PM
OldsAl's Avatar
Way to go Mike. Bet the buyer is one happy camper. Very nice 255 carb. Al
Old Dec 1, 2017 | 11:07 PM
wrong number. Sorry 250-228-1442
olds w-31
Nov 14, 2017 12:48 PM
olds w-31
Aug 17, 2010 01:28 PM
olds w-31
Jul 16, 2010 01:43 AM
olds w-31
Jun 24, 2010 04:57 PM
cutlassw-31
Oct 27, 2009 11:09 AM
