Rear coil springs, 66 442.
Old Mar 2, 2017 | 04:33 PM
tru-blue 442's Avatar
Old School Olds
Includes insulators, $40 + the ride.
Old Mar 5, 2017 | 06:30 AM
Old School Olds
$40+ the ride.
Old Mar 5, 2017 | 08:06 AM
35tac's Avatar
Just a question. Not trying to hijack the thread. What are the differences between 442 rear springs and Cutlass convertible rear springs, would they interchange. Just for education purposes please.
Wayne
Old Mar 5, 2017 | 08:22 AM
Old School Olds
Good question Wayne. Maybe someone knows the difference if there is one.
I'm always open for a discussion. Knowledge is a good thing in my book.
Old Mar 6, 2017 | 01:48 AM
tbdragon's Avatar
They used so many different springs for different models at GM usually... also I believe main differences on cutlass' were weight distribution for Big blocks(heavier) or small blocks/L6... all 442's had big blocks in 66 most cutlass convertibles had small blocks... but fit would be fine especially good if the cutlass convertible has a big block now that needs the stronger springs... but to balance it you would want big block springs in front also I would think... if you order front and rears at PST or JC whitney etc. they sell different springs for small block/6 cyl and big blocks...
Old Jul 30, 2017 | 05:52 AM
Old School Olds
Bump, $40 + ship.
Old Jul 30, 2017 | 08:51 AM
Roger60's Avatar
Springs
Also not to hijack, I was on a site that sells springs (can't remember where it was now) and there was a different spring for just about every model of 67 Cutlass at least. Coupes had one type, sedans another, different engines of course. I thought my 67 conv. sat too high and instead of buying lowering springs, I cut one coil out of the front (you can do that on the front) dropping it 2 inches. For the rear, I used stock springs from a 4 dr sedan which lowered the rear. I also cut the top small coil from the convertible spring and installed them on the rear of my 65 Buick Special conv which took the sag out of the rear and gave it a slight lift and better stance.
Old Jul 30, 2017 | 09:06 AM
Old School Olds
I don't know if it helps or not, but these were under a 66 442 hardtop rot box.
The rear end I believe was the original 3.32 posi that had an upgraded gear set.
Old Feb 12, 2018 | 02:51 PM
Old School Olds
$45 + the ride.
Old Aug 15, 2018 | 06:38 AM
Old School Olds
Bump.
Old Aug 15, 2018 | 09:18 AM
68442's Avatar
Might you have the fronts as well??
Old Aug 15, 2018 | 09:39 AM
Old School Olds
Wink
I don't. But I have the original rear springs from my 69 442. That probably doesn't help though.
Old Jun 25, 2019 | 06:43 PM
Old School Olds
Bump.
442oldz71
Apr 28, 2018 10:35 AM
Chuxter
May 14, 2014 07:37 PM
yankees
Suspension & Handling
Oct 18, 2011 08:43 AM
rhaberm
Aug 2, 2011 01:28 PM
iuhoops83
Mar 17, 2008 05:54 AM
