dual bale disc brake master
Old Jan 26, 2017 | 05:54 PM
junior supercar's Avatar
was told it's from a 67. has been sitting for several years so needs to be gone through. US code. $100 plus shipping.
Thanks,
Chris
Old Jan 26, 2017 | 07:57 PM
2blu442's Avatar
Chris, would you look at the bottom and post the casting number? Since it has the bleeders I'm guessing its GM original so there should be a number there.
Old Jan 27, 2017 | 12:16 AM
hurst68olds's Avatar
looks like "US" is originally a '69 Camaro piece
what's the correct stamping for a '67 and '68 Olds a-body?
Old Jan 27, 2017 | 06:15 AM
442Fred's Avatar
EA is correct for 68 and 69
Old Jan 27, 2017 | 08:05 AM
well that's good to know. Thanks.
Old Jan 27, 2017 | 08:07 AM
Fred are you sure for 68? I thought DW would be for 68. agree EA is 69.
Old Jan 27, 2017 | 08:08 AM
yep, original GM. it's the standard disc master casting number. I used to have it memorized, but I'll double check before going off memory.
Old Jan 28, 2017 | 06:33 AM
72xw30's Avatar
68 Hurst Olds is "DW"
68/69 W30's are "CT"
Old Jan 28, 2017 | 09:31 AM
CT is actually for many years (67-72 I think). it's manual and power drums. I have it on my W-31 and my manual drum brake pontiac has it also.
We are discussing the disc brake code for 68
Old Jan 28, 2017 | 11:06 AM
72xw30's Avatar
Thank you
Old Jan 30, 2017 | 02:37 PM
RocketDevo's Avatar
The code's for 1968 are, Drum whether manual or power is "CT" if it is Disc. it is "DW"
1969- Drum "CT" Disc. "EA"
1970- Drum "CT" Disc. "EB"
1971- Drum "CT" Power Disc. "BE" Manual Disc. "ST"
1972- Drum "CT" Power Disc. "BE" Manual Disc. "ST"
The "CT" code was widely used by all divisions. There is also a "DP" drum master cylinder but I am not certain of its application. The code "BE" was also used by Pontiac and Buick in 1971-72. The casting number for power disc brakes master cylinders from 1970-1972 for all GM divisions is the same. The manual disc master cylinder in 1971-72 is a tall dual bale design.
It is the only master that did not come with bleeders.
Old Jan 30, 2017 | 04:36 PM
now that's good to know, thanks. I knew a majority of it, but good to have it all in one place now.
back to the original post. 69 camaro disc brake master. Maybe I should put this on the yenko site.
Old Feb 24, 2019 | 06:47 PM
sold
Bernhard
Aug 4, 2018 11:23 AM
tru-blue 442
Apr 13, 2016 04:57 AM
442mark
Jan 6, 2016 11:43 AM
junior supercar
Nov 25, 2014 12:56 PM
oldspackrat
Aug 8, 2014 04:06 PM
