1967 442 400ci Big Block Engine
Old Mar 12, 2016 | 01:35 PM
Slater442's Avatar
All Id #s make it out to be a 1967 400 "E" Block 442 engine, from 4 speed car.
Complete engine in great condition, all major parts cleaned, magnafluxed, and inspected.
Parts Included: engine block, crank shaft, rods & pistons, Complete cylinder head assemblies, intake manifold, oil pan, valve covers, cam and pushrods, front cover, oil fill tube, Manual trans flywheel, harmonic balancer, and all nuts and bolts and misc brackets.
Crank is at zero.
Not willing to part out.
Estimated weight of 600lbs
Engine Located in Eugene, Oregon.
$1500 (shipping not included)
Old Mar 12, 2016 | 01:41 PM
tru-blue 442's Avatar
Old School Olds
Good deal.
Yummy...payments?
Old Mar 12, 2016 | 04:30 PM
2blu442's Avatar
Brian, the intake looks like a 1965 as its a square bore. That was 1965 only for the big blocks & would have had a 4 jet carburetor. The 1966 & newer would have spread bore intakes with quadrajets. Also could you add one photo of the back end of the crank showing the pilot bushing? John
Old Mar 12, 2016 | 04:32 PM
2blu442's Avatar
One more thing... if you would post the Julian date of the castings, block & heads that might help people match this to a car they may have missing the correct engine.
John
Old Mar 13, 2016 | 06:00 AM
OLDScience's Avatar
Is there a way to determine if an E Block is 66 or 67?
Old Mar 13, 2016 | 10:34 AM
Octania's Avatar
I agree that the intake appears to be '65. Provide casting #?
The block has that date thing near the dist'r hole. Allegedly it goes like this:
would be #1 **calendar year** of production for this type of block: e.g., 1967 for the model year 1968+ "F-455" blocks, 1965 for the '66-'67 model year E-400 blocks. Therefore "2" on an E400 would be cast in 1966, and "3" in 1967, and none after that.
The "359" could be digits from 1 to 365 [or 366 in a leap year]. None of '65, '66, or '67 were leap years. In this example it would be day #359 of 1965... an unrealistic example perhaps, because Day 359 is usually Christmas Day, and folks are probably not casting blocks on that day.
So, assuming that model year changeover occurs around day 210, and assuming that an engine block would be cast no closer to use than say 30 days....
1966 Model year cars would have blocks cast
1- from ealiest to 365, and then
2- from 1 thru 180 [or so, based on ASSUMPTIONS above]
1967 Model cars would then have blocks cast from
2-181 [or so...] thru
3-180 or whenever they stopped making E blocks.
ozolds
Jan 11, 2016 09:25 AM
TicTocTach
May 14, 2015 07:18 AM
Flye
May 22, 2011 10:42 PM
rida142
Jul 22, 2007 09:25 PM
rida142
Jul 15, 2007 03:27 PM
