O-axle positraction rear ends
Two rear ends for sale:
2.78 positraction O-axle rear end. SB code. Fits 64-72 A body. Housing has some rust and pitting. Internals very good. Backing plate to backing plate. $550
3.08 positraction O-axle rear end. SD code. Very clean. Has been painted. Backing plate to backing plate. Needs upper control arm bushings and one axle needs axle studs. Very clean inside. $800
Prefer pickup at my location. Hebron, Illinois 60034
Any idea what year they are? Early ones (1969-older) have sealed axle bearings and an oil seal pressed into the tube end; later (1970) have an open bearing and the oil seal sandwiched on the axle shaft between the bearing and the backing plate, the same as the 71-up corporate 10 bolt rears.
