O-axle positraction rear ends
Old Oct 10, 2016 | 03:07 PM
Bob Kelso's Avatar
Two rear ends for sale:
2.78 positraction O-axle rear end. SB code. Fits 64-72 A body. Housing has some rust and pitting. Internals very good. Backing plate to backing plate. $550
3.08 positraction O-axle rear end. SD code. Very clean. Has been painted. Backing plate to backing plate. Needs upper control arm bushings and one axle needs axle studs. Very clean inside. $800
Prefer pickup at my location. Hebron, Illinois 60034
Old Oct 10, 2016 | 03:21 PM
Any idea what year they are? Early ones (1969-older) have sealed axle bearings and an oil seal pressed into the tube end; later (1970) have an open bearing and the oil seal sandwiched on the axle shaft between the bearing and the backing plate, the same as the 71-up corporate 10 bolt rears.
Old Oct 11, 2016 | 11:32 AM
anthonyP's Avatar
Messages sent.
Old Oct 11, 2016 | 01:28 PM
Bob Kelso's Avatar
Both housings have the 402227 casting numbers on the center section . They are both the 67-69 sealed bearing type . BOB
Old Oct 12, 2016 | 11:23 AM
Magna86's Avatar
Correction those are 1970 rears as per the 402227 casting # and will have open roller bearings with oil seal.
Old Oct 12, 2016 | 03:15 PM
Bob Kelso's Avatar
The casting numbers are correct for the 1970 o-axle . They will fit the 67-70 cutlass body .
Old Oct 12, 2016 | 04:57 PM
oldsmobiledave's Avatar
Fyi
They will fit a lot more cars than that. Good luck with the sales.
Old Oct 12, 2016 | 06:15 PM
anthonyP's Avatar
Message sent.
Old Oct 13, 2016 | 06:15 AM
Bob Kelso's Avatar
Anthony , no message came through . BOB
oldsvair
Oct 29, 2020 08:10 AM
monzaz
Jan 19, 2011 09:22 AM
442 Guatemala
Jun 11, 2007 10:19 AM
Cutlass73V8
Apr 20, 2005 07:55 AM
rocketman67
Jun 21, 2004 04:06 PM
