FS: Hotchkis Rear Sport Sway Bar (#2202R)
Old November 16th, 2011, 08:40 AM
oldzy's Avatar
Hotchkis 2202R Rear Sport Sway Bar bought new from Summit Racing as part of TVS kit, but will likely be using another style (like original) 1" instead. Just the bar is included, no bolts. Pic below. Mounted a short while (not tightened), then removed.
$100. Pickup only.
oldzy is offline
Old November 16th, 2011, 07:10 PM
507OLDS's Avatar
That is a great bar.I have one on the 72,and just recieved one for a customer's car that I am doing saturday.Yours looks farther away from the rear cover,compared to the ones that I have done,but you also do not have your suspension under load,which will change the control arm positions,and move the bar upward when loaded.
507OLDS is offline
Old November 16th, 2011, 07:25 PM
oldzy's Avatar
Here prob a dumb question... but are the front and rear bars 'matched' for each other 'size' wise and/or 'shape' wise?
For example... would any 1" rear bar (regardless of shape) work just the same with the front Hotchkis 1 3/8" bar?
My only beef really with this bar is the 'shape'. I was hoping to find a original v-shaped style original in 1". However, the only one found so far is made in China.
oldzy is offline
Old November 17th, 2011, 05:33 AM
507OLDS's Avatar
Generally,the front swaybar is thicker than the rear.If you go with a thicker one in the rear,then you normally upgrade to an thicker one on the front.My 72 only has a rear bar,as I removed the front one,but I don't carve the cones with that car.It wasn't too long ago that I was able to get a new GM rear bar from the dealership,but not sure about now.You could also check with Fusick.There were 2 different styles that I have seen come from the factory.One had a definite point,or "V" in the center,and the other style had a more gradual bend.
507OLDS is offline
Old January 15th, 2012, 04:59 PM
oldzy's Avatar
oldzy is offline
Old January 15th, 2012, 06:14 PM
69oldsguy's Avatar
I'm interested, but you said pick up only. What's the reason for no ship?
69oldsguy is offline
Old January 15th, 2012, 06:18 PM
oldzy's Avatar
Too long and hard (oh my)... and no box.
oldzy is offline
oldzy
July 1st, 2012 08:05 PM
oldzy
Suspension & Handling
April 11th, 2011 07:35 AM
oldzy
January 3rd, 2011 02:38 PM
oldzy
December 3rd, 2010 08:20 AM
oldzy
November 30th, 2010 11:33 AM
Quick Reply: FS: Hotchkis Rear Sport Sway Bar (#2202R)
