DSS Pistons, Rings, Rods, 350 Nodular Crankshaft: Balanced Assembly $350. NE TN
Old Jan 3, 2022 | 11:59 AM
65Delta's Avatar
Up for sale is the complete, balanced assembly I was going to use in my first 350.
The pistons are DSS FX 1-6020-4100 (0.040" over) and are brand new.
In my opinion, 3 of them should be replaced due to handling/installation damage. This & the cracked block were the heart of the disagreement I had with White's. Machine shop #2 wanted a fresh start so these parts went unused. Shop #2 didn't inspect/reject any of these as I procured another core engine and we built that one up.
I didn't see any issues with the other 5:
Rings are Total Seal CR3690 105 and are new:
Crank is Nodular, OE Olds 350 from a 72 with auto trans:
The crank was not ground, only polished. There are a few fine scratches but they don't catch a finger nail. To be safe you can have the crank ground 0.010" under.
The assembly was balanced using a standard Pioneer Flexplate (FRA-102) and a Dayco Powerbond Damper (PB1147N). If you procure these the assembly will remain balanced:
Asking $350 obo for the above. I'd prefer local pickup (Johnson City, TN area) but can look into shipping.
. I also have a set of new King (EngineTech) crank/rod bearings. If you'd like these as well I'm asking $50. They are new in the plastic:
Old Jan 15, 2022 | 08:51 AM
coppercutlass's Avatar
Chevy budget Olds powered
How damaged are the pistons
Old Jan 15, 2022 | 05:25 PM
65Delta's Avatar
I tried to get some close-up pics of each of the 3 pistons to better explain what I saw.
2 of the 3 pistons have witness marks from installation near the wrist pins:
1 of the 2 with witness marks also has a ding on the piston skirt:
The 3rd one has a mark or gouge on the side between piston ring grooves:
All 3 have some white/gray splotches. The 5 other ones do not exhibit these but they were in a separate box:
Old Feb 24, 2022 | 05:17 PM
65Delta's Avatar
Bump
Old May 16, 2022 | 05:41 PM
65Delta's Avatar
bump
Old Jun 22, 2022 | 07:02 PM
65Delta's Avatar
bump
Old Aug 1, 2022 | 03:27 PM
65Delta's Avatar
ttt. Now $300
Old Oct 9, 2022 | 07:30 PM
65Delta's Avatar
ttt. Now $275
Old Nov 1, 2022 | 10:10 AM
Interested in the rod bearings. Didn't see the price change. I'd pick that stuff up if still available.
Old Nov 1, 2022 | 03:42 PM
Alaska442's Avatar
parts
Im intrested in the parts lot if you can ship them to me in Alaska
You can contact me by email Olds.nw@gmail.com
Old Dec 10, 2022 | 11:31 AM
65Delta's Avatar
Sent you a PM. Sorry I haven't been on in a while & just found the message.
I'm intrested in the parts lot if you can ship them to me in Alaska
Not sure how I'd ship the crank. I don't have a box long/thick enough for it.
Old Dec 17, 2022 | 05:59 PM
65Delta's Avatar
Sold!
Dec 21, 2021 03:41 AM
olds 307 and 403
Dec 15, 2021 11:51 AM
coled18
Oct 8, 2021 11:12 AM
Johny
Jul 22, 2021 06:16 AM
grannys442
Apr 24, 2021 07:12 PM
