66 425 Engine Complete, Running, Less Carb
Old December 11th, 2021 | 01:16 PM
Oldsmaniac's Avatar
Engine Sold 3-7-22
Old December 11th, 2021 | 10:34 PM
oldstata's Avatar
Justin
Just picked up a 66 98 parts car and will be pulling the HC 425, 4bbl with B heads. Runs with no taps or noises, or smoke.... don't know much about the history probably has high miles $650 Offers? Central NJ is location.
good deal wish you were closer.
Old December 12th, 2021 | 06:12 AM
jmcghee's Avatar
Does it come with alternator ps pump and brackets?
Old December 12th, 2021 | 07:36 AM
Oldsmaniac's Avatar
I can include for full price $650 AC brackets also but no compressor. Exhaust manifolds also.
Old December 12th, 2021 | 08:50 AM
Gmar442's Avatar
Do you happen to have a transmission with it?
Old December 12th, 2021 | 04:50 PM
Oldsmaniac's Avatar
Trans is available also, long tail turbo 400 switch pitch. $150
Old December 12th, 2021 | 06:27 PM
Gmar442's Avatar
Ok thank you, I don't know much about the switch pitch transmissions - is it an auto or manual?
Old December 13th, 2021 | 05:15 AM
Oldsmaniac's Avatar
The Turbo 400 is an auto trans, this style used in 65 thru 67 full sized Oldsmobiles.
Old December 13th, 2021 | 06:20 AM
sysmg's Avatar
Switch pitch is a great transmission. But you need a switch to change the pitch. 65-67 fullsize came with the switch in the throttle linkage. I think some midsize with ST300 also had a switch pitch converter Some people have discussed an electronic switch (I think in Facebook Oldmobile Performance Engines group https://www.facebook.com/groups/1451...974590&__cft__[0]=AZUjAKuZ2uG1EK5terdIwufl0MTw3AogHs3HO-kkllocPNm8X8PlzT6y0Foif1F0IJtVUnkl5cK8km61Tnoy_EF6 TditA_h_cjQeNlanghaNE4lKJhG5QFsadPsT0ZUeCK-pYAP5qdsqsnCj61A27Td8JlDWtlkr_vlfHJku4vchiiH9IFZz8 7l3hOOkrhZnwLA&__tn__=-UC%2CP-R), I didn't really follow the details.
Saw this great description of the switch pitch transmission (copied from someone else's post)From 1964-1967, Buick and Oldsmobile versions of this transmission used a torque converter with a variable-pitch stator called Switch-Pitch (by Buick) or Variable Vane (by Oldsmobile). The stator blades moved from high to low position by an electrical solenoid and a stator valve, controlled by a switch on the throttle linkage. At light to medium throttle, the stator blades were at 32°, providing a torque multiplication of 1.8:1 and a converter stall speed of approximately 1800 rpm. At ⅔ to full throttle, the blades switched to the 51° high position, giving torque multiplication of 2.45:1 and a stall speed of approximately 2300 rpm. The blades were also set to the high position at idle to limit creep when stopped in Drive. The variable-pitch stator was eliminated after 1967
Old December 13th, 2021 | 03:56 PM
blakes7's Avatar
Sounds like a good idea, I wonder why it was discontinued, and not (to my knowledge) used again by anyone else.
Old December 16th, 2021 | 10:23 AM
Oldsmaniac's Avatar
Picture added.
Old December 17th, 2021 | 02:15 PM
Toro X6's Avatar
PM sent.
Old December 17th, 2021 | 02:20 PM
Oldsmaniac's Avatar
Some have asked about fastenal, shipping. At this point I am not willing to go through this additional effort. Thanks
Old December 23rd, 2021 | 02:59 PM
66Resns's Avatar
66Resns
Cornering lamp wiring harness
Hello, did the part's car come with cornering lights? If so, I need the switch and the harness to get mine working. Thanks
Old December 23rd, 2021 | 07:35 PM
Oldsmaniac's Avatar
Sorry no cornering lights on this one...
Old December 23rd, 2021 | 07:55 PM
Charge more for the fuel supply setup!
Old December 24th, 2021 | 05:01 AM
Oldsmaniac's Avatar
Thanks forgot about that!
Old February 16th, 2022 | 07:09 AM
Oldsmaniac's Avatar
To-The-TOP
DR_DAN
August 3rd, 2015 04:00 PM
1969w3155
July 5th, 2013 12:21 PM
j_link
June 23rd, 2011 08:31 AM
j_link
February 11th, 2011 09:59 AM
425cid_260Z
July 25th, 2007 05:05 AM
Quick Reply: 66 425 Engine Complete, Running, Less Carb
