1970 12-bolt O-axle 3:08 posi rear,SD code,restored
Old April 2nd, 2013, 11:18 AM
507OLDS's Avatar
Show-quality restored 1970 12-bolt O-axle SD-code 3:08 posi rear end.This rear is flawless.It was mint to begin with.It came from the southwest,and there is zero pits,scale,or any blemishes.It was disassembled,hot-tanked,bead-blasted,epoxy-primed,and urethane-coated satin black.Original GM gears are perfect.Posi unit rebuilt with new clutches,and all Timken bearings/seals installed.Reassembled,filled with fluid & additive,and ready to run.Backing plates are included,but no brake hardware. $1400.00 plus freight.
Complete new drum brake package available for an additional $250.00.
507OLDS is offline
66-3X2 442
August 8th, 2014 12:28 PM
507OLDS
August 7th, 2014 10:12 AM
507OLDS
December 12th, 2013 06:36 PM
monzaz
January 13th, 2013 05:33 PM
monzaz
October 2nd, 2012 04:49 AM
Quick Reply: 1970 12-bolt O-axle 3:08 posi rear,SD code,restored
