1964-72 GM Front Disc Brake Conversion Kit
Old May 22nd, 2010 | 08:17 AM
cutlassjoe's Avatar
We have brand new GM disc brake conversion kits. These will fit 1964-72 Olds Cutlass/442.
These are brand new kits with all the necessary hardware and fasteners. Shipping is free.
Price is $530.00. Let me know if you are interested. Thanks.dbk6472_03ebay.jpg
Old November 24th, 2010 | 05:07 PM
64 CUTLASS KEN's Avatar
four wheel disc brakes
I have a 64 cutlass that I would love to put a nice four wheel disc brake conversion. im runnun 17" cragers on it, and you can see alot thru them, I want to paint up a set so I want them to look good. Do you offer a four wheel set? and if so how much would one be?
Old November 25th, 2010 | 04:09 PM
cutlassjoe's Avatar
Yes we do. I will pm a price to you on Friday. If anyone else is interested please let me know. We can set you up with front disc, 4 wheel disc, and all the necessary brake lines. Either stainless or oem.
Joe
Old March 18th, 2015 | 10:45 PM
Kid Thunder's Avatar
14"
Will these front kits work with 14" wheel?
Old March 19th, 2015 | 09:19 AM
Factory disk brakes came with 14" wheels. Be aware that not all 14" wheels have the same backside contour. GM made a lot of cars with the older style 14" wheels that will not clear. You need to know which style 14" wheels you have.
Old March 19th, 2015 | 10:13 AM
dalilama's Avatar
I have 14" wheels - they are the SS1 rallye type but I don't think they are original to the car. I'm hoping they are compatible with the factory disk brakes (I have drum now), but how do I determine which "style" they are?
Old March 19th, 2015 | 10:18 AM
SSI wheels were made both ways. The early 14x6 versions do not clear disk brakes. The later 14x7 versions do clear. Post a photo of the backside of the rim.
Old March 19th, 2015 | 10:21 AM
dalilama's Avatar
Thanks - I'll pull it off tonite and post a pic.
Old March 19th, 2015 | 12:52 PM
Skeetman's Avatar
I have converted from drum to disc brakes 11" from CPP and my 14" wheels fit and clear. My wheels are SS III 14" X 7" wide rims. I was told the 14" X 6" wide rims will not fit disc brakes.
Old March 19th, 2015 | 01:26 PM
14/6
Well I guess that answers my question. I was trying to leave the car stock appearing with 14" steel wheels & stock hubcaps. I'm pretty sure they are not 14/7.
Old March 19th, 2015 | 03:09 PM
They would be wrong. The factory installed 14x6 Super Stock II wheels (which are identical to SSIII except for paint color) on disc brake cars in the 1968 and 69 model years. I have personally put 14x6 SSII wheels on cars with factory disc brakes.
Please read my prior post carefully. We are talking about Super Stock ONE wheels only. The issue isn't the width (think about, wider rims make clearance worse). The issue is the shape of the backside of the rim. There are lots of 14x6 wheels that clear factory discs. The 14x6 SSI wheels do not.
And yet again (sorry, but I've typed this many, many times over the years here), ALL SSII/III wheels clear factory disc brakes.
Old March 19th, 2015 | 03:35 PM
bigin1978's Avatar
wasn't there a 14x6 that was like jk code or something that would clear disc brakes?
Old March 19th, 2015 | 05:05 PM
dalilama's Avatar
OK - Per Joe's request here is a few backside pics of the SS1that I am trying to figure out if it will fit over a disk brake (OEM or otherwise). They are 14" for sure, but I'm not sure if they are 14x6 or 14x7, or if they are the right 14x6 per Joe.
Last pic is for someone to confirm I have an SS1 (with a trim ring).
I'm betting this is a SS1 for a drum....
So what's the verdict?
Old March 19th, 2015 | 05:42 PM
bigin1978's Avatar
that should be a 70-72 ss1 the early wheels did not have trim rings. I believe that will work with disc I think there is a number under the trim ring by the valve stem
Old March 19th, 2015 | 06:01 PM
So the only way for me to know if my stock 67 steel hubcap rims is to try them, correct?
Old March 19th, 2015 | 07:07 PM
dalilama's Avatar
There are 3 numbers and what looks like a symbol of some sort. No idea what they mean...
Old March 20th, 2015 | 04:56 AM
Uncle Hulka's Avatar
Ancient Olds Lover
I will always defer to Joe when it comes to anything Oldsmobile. That being said, my late build (06D) 1969 Cutlass S has its original 14x6 SSI wheels. It was a power drum brake car. I converted the fronts to disc using a used, but complete setup from a 1970. I knew the original SSI's would not fit so I didn't bother to even try to put them on when we completed the conversion. I already had a set of 15x7 SSII's that I knew would fit, since they came off a disc brake car. One of my friends who helped with the conversion didn't know the SS1's wouldn't fit, so while I was off doing something else, he put them on. I saw them on and called over to him "Hey, those don't fit anymore. Take 'em off." He looked at me, smiled and spun the front wheel. It spun perfectly without any clearance issues.
Joe has forgotten more Olds information than I will ever know, but I can say this; My late-build SSI 14" wheels do fit over factory disc brakes.
Old March 20th, 2015 | 07:33 AM
dalilama's Avatar
Well now you got me totally confused... That's what makes this stuff fun
Old March 20th, 2015 | 07:49 AM
70cutty's Avatar
Beer Connoisseur
My Cutlass had drum brakes and 14x6 steel wheels with hubcaps. After I did the conversion I tried them on and realized that 2 of the wheels will clear the brakes and 2 of them wouldn't.
Old March 20th, 2015 | 07:55 AM
These should clear.
Old March 20th, 2015 | 08:01 AM
dalilama's Avatar
Thanks Joe -
Old March 20th, 2015 | 10:14 PM
So back to my original question. As 70cutty said that 2 of his 14" hub cap wheels fit & 2 didn't. So is the only way to know is to try them on after I do the front disc conversion!?
I really didn't want to find out later I have to buy wheels. No #s stamped on the wheels to match up? I really want this car to look like a "sleeper" after I'm done. Like a Road Runner idea but it's an Olds!!!!!
Mocephus
October 1st, 2021 09:45 AM
crazycowboyny
April 29th, 2014 02:33 PM
yeahbuddy
February 12th, 2014 07:14 PM
Charles Welty
December 3rd, 2010 07:44 AM
jeffu231
Brakes/Hydraulic Systems
July 15th, 2009 07:51 PM
Quick Reply: 1964-72 GM Front Disc Brake Conversion Kit
