12 bolt chevy posi gear and rebuild kit
SAME DEAL AS THE 8.5... HERE IS A 12 BOLT CHEVY DEAL!
LIMITED QUANTITY HOLIDAY SPECIAL DEAL.... THIS IS ALL BRAND NAME STUFF NOT LIKE IN THE BAY.
OTHER RATIOS AVAILABLE AT A DIFFERENT COST....
NEW YUKON EATON POSI UNIT 349.00
NEW 3.73 YUKON PREMIUM GEARS 149.00
NEW REBUILD KIT 79.00
577.00 TOTAL
HAPPY HOLIDAYS!
JIM
JD
PM WITH ZIP CODE FOR SHIPPING PRICE.
577.00 TOTAL
HAPPY HOLIDAYS!
JIM
JD
kit includes the following parts -2 carrier bearings and races, 1 inner pinion bearing and race, 1 outer pinion bearing and race, 1 Pinion seal, 1 pinion crush sleeve,1 pinion nut, 1 rear inspection cover gasket, 1 carrier pack of carrier shims, 1 pinion pack of shims, 1 marking compound and applicator brush, 10 ring gear bolts, 1 booklet to help you with your set-up pattern and torque specs.
Thank you
Thank you
