Underbody of 72 cutlass
Old Mar 18, 2013 | 04:45 PM
Oldssupreme's Avatar
Chris
I have refinished all the suspension parts and frame with either paint or powder, but now i am unsure of what to do under the car. There is a ton of tubber undercoating and grease. How should i remove the grease and prep and paint the underbody?
Thanks, chris
Old Mar 18, 2013 | 08:18 PM
O's_Car's Avatar
Hey Chris, a couple years ago the TV show MuscleCar cleaned up the underbody of a Camaro they were restoring. Here's a link to what they did (skip to about 11:20 on the timeline):
http://www.powerblocktv.com/episodes...s-and-rear-end
Those guys used spray-on engine enamel on their underbody, but Eastwood sells a spray-on rubberized undercoating that you might also consider.
When my Cutlass was at the body shop they removed all that under-gunk with hand scrapers and wire wheels. It took a lot of time and elbow grease and left a big nasty mess on the floor, and they had the body on a rotisserie for easy access. We went with a custom finish - they sprayed the underbody with Line-X tinted to match the body paint color.
Just a couple ideas for you to consider.
Old Mar 19, 2013 | 05:57 AM
Chris
Oskar, great, thanks very much, ill check out that link.
Chris
Old Mar 24, 2013 | 06:24 PM
jstrits's Avatar
I had rust free floors on a 71 I'm finishing up. someone though years ago decided to "freshin it up" with spray can undercoat. I used heat gun and scraper first. Then always use a wire knot wheel on a 4" grinder. Then I 80 grit da sanded the whole thing. etch primed, then satin black the whole thing and then duplicated the factory overspray patterns. My car had original green paint all over but the undercoating was a mess. very time consuming.barefloors3.jpg 20442/progress18.jpg[/IMG]
Old Mar 28, 2013 | 11:53 AM
Chris
wow, that underbody looks great! thanks to both of you for the info!
Chris
wills30
Aug 18, 2014 06:28 PM
Speednut81
Jun 20, 2013 01:31 PM
jeffsims
Feb 10, 2013 06:34 PM
Del70
Mar 16, 2012 07:11 PM
Frankenpez
Feb 2, 2009 07:03 PM
