Trunk paint advise
Old Apr 14, 2012 | 10:06 PM
Al Graaf's Avatar
Formerly "Shimmer"
Trunk paint advise
I have heard Parts Place has a good trunk splatter paint (60-70 qt) that is right on it. Also, Eastwood has the rattle can paint and clear coat (48)
The rattle cans, I can do to speed the process up, but is it best to use "the real" stuff from a gun. Don't want it running if it gets wet as I have heard. Comments gentlemen?
AL
Old Apr 15, 2012 | 04:43 AM
DarrylJ's Avatar
I would rattle can it and be done with it. I put a mat also in the trunk of my 70 so not to scratch the floor. Also with the rattle can you can touch it up later very easily if needed. I like to keep things simple as possible!
Old Apr 15, 2012 | 06:23 AM
Al Graaf's Avatar
Formerly "Shimmer"
That's where I was heading. Keep it as simple as I can. Other way you got to buy the paint, mix it, spray it , involve someone else...will order that today.
Thanks for the advise!
AL
Old Oct 28, 2014 | 06:59 PM
ah7910's Avatar
Sounds Like a Plan! I need to tackle as well.
a couple Years late to the show....
One Quetsion:
How about getting rid of Old Adhesive lines from holding down carpet?
Old Jan 25, 2015 | 08:56 PM
67442nut's Avatar
Make sure you're not spraying the spatter paint on bare metal.
Most of the trunk spatter paints are water based and will allow moisture
to soak through and rust the metal below
if it's not coated with something that's water proof.
You'll start seeing rust stains in your new paint.
I learned the hard way.
Old Jan 26, 2015 | 06:12 AM
ah7910's Avatar
Great tip thanks,
I have a few many coats of black primer sanded and reapplied as I'm a bit **** about that. on top of the rust kill ( even though there was no rust. )Thanks to the forum We find many recommendations of por10 etc.
Nice ride btw
Big Cee
Drivetrain/Differentials
Jan 27, 2008 05:52 PM
Cecil Anderson
Nov 4, 2007 12:00 PM
thomaswatk
Apr 7, 2007 03:41 AM
hodgeman
Jan 23, 2007 10:15 AM
DAVID ROSS
Jun 6, 2006 07:47 AM
