Tips for painting an engine?
Old May 4, 2009 | 08:41 AM
bittersweet71's Avatar
Any tips from those with experience?
Old May 4, 2009 | 09:03 AM
tips
1] Take it out
2] Clean, clean, clean
3] Clean some more
4] Buy engine paint
5] Apply engine paint
You can accomplish 2 & 3 in several ways like engine cleaner and presssure washer.
Old May 4, 2009 | 09:25 AM
Eric Anderson's Avatar
3] Clean some more
x2 you can't clean it enough
Old May 29, 2009 | 02:32 AM
redvettemike's Avatar
I have some friends that are using Imron paint on their engines. This over a good high temp primer. That Imron paint is so tough. I have seen one of their engines that was painted (Chevy orange) over 10 years ago that looked like it was painted yesterday. However, beware of the fumes of this stuff. i think that a paint jobber can mix it in various colors. Imron is used of stuff like airplans, over the road trucks, UPS fleet, etc.
Old May 29, 2009 | 09:33 AM
rocketraider's Avatar
Oldsdruid
Cheap aluminum foil and good masking tape are your friends. The cheap aluminum foil will mold to about anything you want to mask off and is then e-z to remove. You want the good masking tape so it will pull loose easily. Masking tape is not an area to cut corners.
Precleaning? brake cleaner cleans off grunge and then evaporates leaving a clean surface for paint.
In my experience cheap black spray paint works fine on black components. I tend to go for Krylon or Seymour for cast metal finishes. Engine color paint almost has to be ordered from one of the Olds vendors.
Thor
Paint
Sep 10, 2010 03:24 PM
Steve Wike
Jan 31, 2010 10:01 AM
317rcampbell
Paint
17
Nov 25, 2009 04:28 AM
60Olds98
Aug 19, 2008 05:58 PM
xlntryde
Nov 15, 2007 03:26 PM
