Primer engine block ?
Old Jul 20, 2010 | 05:54 PM
oldsmansugar's Avatar
Should i primer the engine block before i paint it with hi temp paint.
what kind of primer is best.
I will be painting over some of the old paint
Old Jul 20, 2010 | 06:17 PM
80_cutlass's Avatar
I've had good luck using a high temp engine primer from dupli-color. I also have used cast iron grey color as a primer on the block. Good success both ways.
I have even used high temp paint straight onto the block, but usually have to use a can or more extra to get it to look right.
The biggest thing is getting it clean. If its really oily I like to use brake cleaner on the bad spots. Before I paint, I usually use a tire brush with dish soap to give the block a good scrubbing, hose it off and repeat as needed, followed by air to dry it.
sb
Old Jul 20, 2010 | 08:19 PM
jaymann's Avatar
Do whatever the instructions on the paint tells you.
If it recommends priming then do it. (use the same brand primer as paint.)
The main thing I find is whatever you use, don't lay it on too thick.
Like 80 cutlass said, get it clean first.
Old Jul 21, 2010 | 08:57 AM
Blk71SX's Avatar
blocks aren't primed from the factory. I've seen a lot more problems with top coat not adhering to primer than straight paint adhering to a block. I've painted a bunch of engines not using primer and never had a problem, providing the surface is good and clean.
oldzy
Paint
Jun 21, 2011 09:40 AM
pinky
Paint
Mar 16, 2009 07:03 PM
scudinferno
Oct 14, 2007 02:51 PM
Want-A-Vert
Feb 14, 2007 11:51 AM
American Lead
Dec 18, 2006 05:32 PM
