Painting the door
Old Jul 25, 2015 | 06:02 PM
truckerlary's Avatar
Painting the door
I am wanting to repaint the drivers door on my 83 H/O. I am wanting to paint the black that is between the stripes to remove a couple dings. What paint do I want to use so it will blend in with the rest of the car. (base coat clear coat, acrylic enamel) I'm thinking it has lacquer on it now.
Old Jul 27, 2015 | 11:40 AM
ttt
Old Aug 5, 2015 | 06:36 PM
what paint would the factory have used back in 83? Acrylic enamel?
Old Aug 6, 2015 | 10:55 AM
68442's Avatar
The Paint/process the factory used was dispersion lacquer.
The closest you are going to have to use is Enamel or single stage urethane. Base/clear will give it an entirely different look.
Old Aug 6, 2015 | 11:00 AM
68442's Avatar
Just remembered, TCP Global(California) mixes PPG Lacquer. You could check with them to see if they still can mix that for you in lacquer.
Curts1970cutlass
Feb 21, 2012 04:06 PM
Good_Music_n_Cars
Jan 18, 2008 06:23 PM
xlntryde
Nov 15, 2007 03:26 PM
Ranzan
Mar 27, 2007 08:40 PM
mainedogg72
Jun 29, 2006 11:45 PM
