Original paint on 70’ QAI hood
Old Mar 30, 2021 | 10:56 AM
Post70's Avatar
Here is a close up pic from a QAI hood. It’s on a Oct 69’ build dated car. The hood has the small holes inside the scoops like the first few months of production had and the stripes look correct. The interesting part is the
white paint is below the red. Is there anyway to tell if it’s the original paint before it gets all the way stripped?
Old Mar 30, 2021 | 12:13 PM
fasteddy's Avatar
It looks like you just sanded it into the base fiberglass there. It looks like just one coat of white paint over the black sealer then they mask off the stripe and paint the red.
Pat
Old May 12, 2021 | 07:24 PM
4+4+2=10's Avatar
From the brief exposure I've had sanding my factory OAI hood, I think what you are seeing is a white gelcoat on the exterior surface of the fiberglass hood skin. I have the same thing under my factory primer.
Old May 13, 2021 | 03:38 AM
Post70's Avatar
The white is above the black sealer/primer. The thin red stripe sands off before the the White does. Was surprised of the process but did some research and if you spray white lacquer over red the red bleeds through the white paint.
Old May 14, 2021 | 12:47 PM
ijasond's Avatar
Purveyor of Polyurethane
We always paint first whichever color is easier to mask off. So in this case, I would spray the hood white, mask off the stripes and then paint the body color. But I do not believe they were doing it this way from the factory back then. I’m no expert, but I thought they would lay the stripes on after the car was painted. However, If this hood only only came with stripes, it would make sense that it would have been done this way.
Old Aug 1, 2023 | 06:19 PM
OLE442's Avatar
Looks like the W25 hood I'm sanding down right now. On mine, there is the white stripe, the Viking Blue color, the black primer and then the white which looks like a gel coat to me. I have never hit bare fiberglass as I see it.
I always thought my car had totally been repainted but after sanding on it I believe all but the nose is original paint and the nose of the hood appears to have had a minor repair before my brother bought it in the 80's.
I've also messed with the paint on some spots on the rest of the car and it appears to just have had a couple spots worked and repainted but most of the car appears to be original paint.
Old Aug 2, 2023 | 09:19 AM
70Post's Avatar
The fiberglass part of the factory hood is made of SMC (sheet moulding compound) material.........you won't see anything different as you sand or grind into it. It's a uniform white material all the way through. There aren't any "layers" to it.....just the homogeneous white SMC material.
Old Aug 2, 2023 | 05:37 PM
OLE442's Avatar
So......it's not really fiberglass. And everywhere I hit white under the black primer is the molded hood??
What really throws me off is....I've been using the sanding blocks with the adhesive sandpaper and when sanding on the flat tops of the scoops, I get random high spots that go very quickly to the white. Does the original hood have that bad of a surface from the factory? Like I said, mine appears to be the original one layer of Viking Blue on the hood except a small area on the nose. Seems like I'm going to have to leave some blue and or primer or risk thinning out the high spots?
OLE442
Old Aug 2, 2023 | 06:35 PM
truckman5000's Avatar
W30
Don't sand it, use stripper...for paint on fiberglass
Old Aug 5, 2023 | 08:51 AM
OLE442's Avatar
So Thornton’s Facebook page is incorrect? They say original is old fiberglass technology and they all need heavy prep work to make them look right??
https://m.facebook.com/story.php?story_fbid=pfbid02Vv1TFU4P1D61hC6f3Jp5M3QnSiWx3LMdtZzLoqeQBcH9ZVvh7B1JVYk2xiFJNz2pl&id=152463904791712
Old Aug 5, 2023 | 10:17 AM
70Post's Avatar
There's a possibility that the hoods were Press Molded material (compound)....a "predecessor" of SMC or a process w/many similar features.
What I am getting at is the material is homogeneous.....same appearance all the way through. You may be thinking or looking for a woven fiberglass MAT appearance in the original hood material.....it's not going to be there. The process used on the hood skin didn't utilize any woven fiberglass mat material.
Old Aug 5, 2023 | 03:37 PM
OLE442's Avatar
I can see what Thornton is talking about. While sanding on my basically original paint hood. When block sanding flat areas on the hood there are high and low spots on basically an original hood! At the back of the hood, behind the two scoops when I sanded down below the color, it looks like there is maybe spot putty or something making it smooth before paint. It sands down faster than the primer or the paint. So, it appears that these hoods were far from perfect on the brand-new cars. Just like Thornton said.
jonesolds442
Jul 25, 2018 02:07 PM
nj67
Paint
Dec 18, 2015 06:39 AM
DewChugr
Paint
Dec 13, 2014 04:58 AM
The Bug Man
Paint
Dec 23, 2013 07:51 AM
matviar
Aug 7, 2012 05:36 AM
