Olds 394 Red engine color code
Old October 21st, 2016, 08:11 AM
Jandk's Avatar
I have searching around here to find some old post, but havent anything ells but where to buy it. I am overseas and like to know what the color code for my 394, so I can buy the paint local.
Does anyone know of the red 394 color code??
Jandk is offline
Old October 21st, 2016, 08:49 AM
Tedd Thompson's Avatar
Probably your best bet would be to take it to a good automotive paint store in your area and have them match it. Other wise Eastwood use to have it and I think they ship overseas .... Tedd
Tedd Thompson is offline
Old October 21st, 2016, 09:01 AM
Jandk's Avatar
I simply dos not have anything with paint on it to do a match.. ☹️
Jandk is offline
Old October 21st, 2016, 09:20 AM
Don R.'s Avatar
I'm sure the purists will cringe, but I just used "Ford Red" which is available anywhere.
Don R. is offline
Phantom Phixer
Charlie Jones's Avatar
Ford Thunderbird red from the 50's is supposed to be a real close match.
Should be available from Ford parts suppliers .
Charlie Jones is offline
Old October 21st, 2016, 09:41 AM
I've heard the same thing in the past..... Tedd
Old October 21st, 2016, 11:49 AM
Oldskeeper's Avatar
The best match I have found is Dupli-color red engine enamel.I bought it at Canadian Tire a parts supply store through out Canada and I believe Whites in the United States. The number on the label is CDE 1653 RED, this number might be a Cdn Tire number but a store over where you are might be able to cross reference it hope fully.
Steve
Oldskeeper is online now
Old October 21st, 2016, 12:23 PM
Jandk's Avatar
A close enough paint is more than good enough for me, but close enough would be nice, so I will have a look at Ford Red or Thunderbird Red. That is very usefull info :-)
Oldskeeper.. I did find that info, and that would have been easy this way, but nobody I found here in Denmark stock this Dupli Color DE-1653 and only one supplier can and will import it for me, BUT the problem is that spraycans is considered dangerous, and it will cost 10 times the paint in shipping because of handling. In $ it would be something like $300-320 .......for 4-5 cans....... Its not worth it
Yes.. cross ref the number only made people look wierd at me. Maybe it was to much work compared to the normal process of repairing scratches.
And again... a close enough color will be fine.. if available.
Jandk is offline
Old October 21st, 2016, 12:35 PM
Jandk's Avatar
When you say Ford Red.. would mean something like Armor Paint A86 Ford Red ? Because that I just found in stock here.
Jandk is offline
Old October 21st, 2016, 04:52 PM
Kahuna's Avatar
Fusick Automotive sells it:
http://www.fusickautomotiveproducts....?number=EP110S
So does USA Parts Supply:
http://www.usapartssupply.com/upload...75_catalog.pdf
(page 90 in the catalogue)
Kahuna is offline
Old October 21st, 2016, 05:43 PM
Phantom Phixer
Not all 394 engines were red .
The low compression (8.75 to 1) engines were painted a medium green with a black air cleaner .
High compression (10.25 to 1 ) 2 barrel engines were painted completely red with a black air cleaner.
High compression 4 barrel engines were painted red with silver valve covers and air cleaner.
Starfire engines were painted red with unpolished chrome valve covers and air cleaner .
Old October 21st, 2016, 11:49 PM
Jandk's Avatar
Still a problem with areosol cans and shipping, but thanks
Jandk is offline
Old October 21st, 2016, 11:51 PM
Jandk's Avatar
Yes correct... and mine was red for sure. High Comp 4 Barrel with silver valve covers and air cleaner.
Jandk is offline
Old October 22nd, 2016, 06:59 AM
coldwar's Avatar
Yes Ford red is very close. Don't confuse the color with the almost maroon color seen on original assemblies today, it's aged. This was the Ford red used in the early sixties, I think 6cyl, 221 and the last of the 292 engines to 1962. Strange thing but it's still widely stocked even in the big auto parts retailers here.
A good excuse to post this again:
coldwar is offline
Old October 23rd, 2016, 06:54 PM
Phantom Phixer
Bill Hirsch Automotive has Ford red available in quart cans .
Might make shipping a lot easier for you .
http://www.hirschauto.com/ENGINE-ENA...OR%20TBR%20RD/
RAMBOW
December 7th, 2017 07:22 PM
47 Convertible
Paint
December 26th, 2013 07:49 PM
sx455raidercelticfan
July 23rd, 2010 07:11 PM
gearheads78
September 25th, 2009 02:05 PM
rrielley
February 9th, 2008 10:43 AM
Quick Reply: Olds 394 Red engine color code
