NOS front fender primer and paint questions
Old May 19, 2021 | 04:18 PM
OLE442's Avatar
I put an original NOS GM passenger fender on to replace the one my brother put a dent in decades ago. The new fender has some type of black primer on it from GM and I was wondering if I would be able to just scuff it up and primer over it before painting?? Or do I have to take it to bare metal? I hope not because it has no surface rust anywhere so I hate to bare the metal.
Also will it hurt anything to put DP0 epoxy primer over the Kondar that is on a couple panels or do I have to sand that all back down to bare metal?
Thanks for any info,
OLE442
Old May 19, 2021 | 04:40 PM
The black primer is e-coat and you can leave it. Scuff and shoot.
Old May 21, 2021 | 06:25 AM
OLE442's Avatar
Thank you Joe!!
Also this question for anyone who knows:
Old May 22, 2021 | 04:15 AM
Post70's Avatar
Would recommend a sealer over the e-coat before paint.
Old May 22, 2021 | 06:43 AM
4+4+2=10's Avatar
Originally Posted by OLE442
Thank you Joe!!
Epoxy primer can be shot over most any substrate as long as you are comfortable with the prep underneath the existing surface. Naturally you will want to scuff the surface first before you lay down the epoxy.
Old May 26, 2021 | 03:30 AM
tommieb's Avatar
On your question about OEM primer. Take a rag with lacquer thinner and soak a spot on new fender and if it softens then remove the primer to bare metal and epoxy primer. Is this a restoration type of job? You can spray epoxy primer over 2K primer with the right prep. Like to know more info tho............
Old May 30, 2021 | 04:24 AM
Brad J.'s Avatar
Spend a 1/2 hour with a 80 grit on a da and get rid of whatever is on the fender. At least do the topside. DP40 is a good product that your putting over over a product you don't know what it is. Do it once and know it's the best you can do.
Mike in SD
Dec 12, 2015 07:39 PM
59Olds98
Aug 4, 2013 08:11 AM
CLcutlass
Body work
Aug 10, 2011 03:40 AM
Del70
May 22, 2011 01:31 PM
malibu406
Dec 10, 2010 07:37 PM
