Non Yellowing Clear for Engine Parts
Old Nov 26, 2023 | 09:46 AM
OLDScience's Avatar
Friends of mine have used clear (PPG) to paint a new intake and it yellowed. From that point on , they never use clear on intakes. I want to clear it a two piece aluminum timing cover (Rocket Racing). I polished it but the material is soft and scratches easily. Does anyone have a known clear that will not yellow in this situation? I may end up powder coating it but trying to save some cash. Is there is a good clear that will also do the job? I have hi-temp engine clear and also some wheel clear (all spray cans), but don't want to get into a two month ok, and then it yellows.
Old Nov 26, 2023 | 09:52 AM
fleming442's Avatar
I use the VHT engine clear; it works well. However, clear over polished might not work so good if the surface doesn't have enough "tooth".
Old Nov 26, 2023 | 10:33 AM
Have you considered using aluminum or steel colored paint? Whatever you use as long as it's engine enamel or designed to resist heat I think you'll be ok.
Old Nov 26, 2023 | 04:15 PM
Bernhard's Avatar
X2
The substrate / surface has to have a tooth and be 100 percent free of contamination for the top coat to have proper adhesion.
Old Nov 26, 2023 | 06:14 PM
OLDScience's Avatar
I sanded it with 600, but that may not be enough grit for it to adhere.
Old Nov 26, 2023 | 06:16 PM
OLDScience's Avatar
I wanted to keep the polished look and protect with the clear. I have used that aluminum paint in the past for alternators with good success
Old Nov 27, 2023 | 03:05 AM
bccan's Avatar
I used BASF (Glasurit and/or Diamont) over the years. Did it yellow? Unfortunately I’m not sure because it was usually over gold basecoat. I can say that in the relatively few that retained exhaust crossover heat, it held up pretty well. Not perfect, but well. I saw no apparent yellowing over BBO blue but can’t say that it didn’t. Sorry, not that helpful, but figured I’d throw it in here.
Old Nov 27, 2023 | 04:55 AM
fleming442's Avatar
I would definitely go with powder coat. It may cloud up a touch, but definitely won't yellow.
Old Nov 27, 2023 | 03:37 PM
OLDScience's Avatar
The March Pulleys are all clear powder coated, and I also recall that I had an aluminum underdrive pully powder coated and it wasn't really clouded.
dal442
Paint
Oct 27, 2017 02:26 AM
67Rocket
Paint
Nov 30, 2016 11:39 AM
1970supremevert
Jan 7, 2014 01:07 PM
Good_Music_n_Cars
Jan 18, 2008 06:23 PM
