No paint code on cowl tag
Old Jan 16, 2017 | 08:16 PM
Donn's Avatar
I have a 70 442. Wanted to know what the factory color is and there is nothing there. If anyone knows why..please help...
Old Jan 16, 2017 | 08:25 PM
sammy's Avatar
Sammy70 455 Supreme
--denotes special order paint
Old Jan 16, 2017 | 09:06 PM
Donn's Avatar
Ok. Thank you for the info.
Old Jan 16, 2017 | 09:07 PM
Donn's Avatar
Is there anyway to find out what the special order paint was?
Old Jan 16, 2017 | 09:57 PM
lemoldsnut's Avatar
Look for a build sheet. I have found two on 70 cars on top of the gas tank. Yes you have to pull the tank to get to it. I have also found them under the rear package tray.
It is my understanding you could get pretty much any GM color for a fee back then
Old Jan 16, 2017 | 10:24 PM
hurst68olds's Avatar
not going to find a build sheet on the gas tank of a LANSING car .....
there were some common "special order" -- -- paints:
"rally red" actual paint code 73
"Aegean aqua" actual paint code 38
"nugget gold" actual paint code 53
as well as 1,000s of other possibilities, best bet is to look under the package tray, behind kick panels or under the sill plates to find some original paint
the "ivory" interior doesn't help to narrow it down
Old Jan 16, 2017 | 11:03 PM
Donn's Avatar
Well maybe its special order color is rallye
red then, since the car is red.. Thanks for the info guys
Old Jan 16, 2017 | 11:37 PM
"rally red" was ..... orange
Old Jan 16, 2017 | 11:41 PM
- the normal red was "matador red" paint code 75
Old Jan 17, 2017 | 04:09 AM
damaged442's Avatar
The most common special order colors I have seen for 1970 were Daytona Yellow, Aegean Aqua and Rally Red, and indicated with the double slash on the cowl tag. It's possible that there are others.
I know in 1973, instead of the double slash, they actually stamped "SPECIAL" into the cowl tag for special order paint codes.
Hopefully, you can find some paperwork or a hint of the original color somewhere to help!
Old Jan 17, 2017 | 04:47 AM
35tac's Avatar
Donn, there is always the chance you can find the original color located in places on the car that normally may not get repainted. Check around deep in the trunk, behind the rear seat, under the dash and places in the engine compartment. Definitely a 442. Nice car. More pictures would be nice. Good luck.
Wayne
Old Jan 17, 2017 | 08:13 AM
Donn's Avatar
Thank you guys! Your help is very appreciative! I will look for paperwork and look behind stuff for original paint color.
Old Jan 17, 2017 | 01:36 PM
vette442's Avatar
To aggregate what was said across several previous posts into one place, your 1970 special order colors were typically Rally Red (orange), Nugget Gold (a butterscotch shade), Sebring Yellow and Agean Aqua.
Terry
Old Jan 17, 2017 | 04:02 PM
Donn's Avatar
Ok. Thank you terry.
Old Jan 17, 2017 | 09:01 PM
oldsmobiledave's Avatar
Yellow
Daytona Yellow? Am I on the Camaro site? Perhaps you meant Sebring Yellow?
Old Jan 17, 2017 | 09:37 PM
Sebring - Daytona somewhere FAST
or maybe Chrysler Corp.'s "plum crazy"
jaunty75
May 29, 2015 04:16 PM
71OldsCool
Jun 20, 2014 06:11 PM
tmaleck
Sep 7, 2012 09:27 PM
Oldsmobomb
Mar 23, 2010 10:03 AM
rrielley
Feb 9, 2008 10:43 AM
