How much paint is needed
Old Oct 18, 2022 | 07:02 PM
4+4+2=10's Avatar
Getting ready to shoot Galleon Gold base/clear on my entire 70 442 (no vinyl top) . Using a white sealer coat. How many quarts of mixed material should I have for the job. I plan a couple of wet coats followed by a drop coat. I do not want to run out.
tc
Old Oct 27, 2022 | 05:25 AM
Post70's Avatar
How much
If you are doing the jambs add a qt but a gallon of mon sprayable would be enough. Wouldn’t hurt to have extra for future insurance.
Old Oct 27, 2022 | 05:40 AM
bccan's Avatar
x2, gallon non sprayable should leave a bit for a future touch up, Heaven forbid.
Old Oct 27, 2022 | 10:46 AM
Andy's Avatar
What product/ paint company are you using? Ppg or? I have the same color and year 442..why the white sealer coat?
Old Oct 27, 2022 | 05:41 PM
4+4+2=10's Avatar
Hi Andy, Using Nason "Ful Base" / Select Clear. Using a white epoxy primer as my sealer coat because I already had a partial gallon on hand. I like using epoxy primer as a sealer coat because it provides protection on places that I've sanded through to bare metal. Otherwise, I would need to use a separate primer on the these spots before shooting an acrylic sealer.
Although I've painted several of my own cars, this is only my second metallic job. My first was 30 years ago and a complete disaster due to my inadequate gun. This a different animal for sure. Maybe I'm just intimidated and worried about mottling or striping, but I ended up using 6 quarts of paint which thinned to 9 quarts of mixed material. I did shoot both sides of the trunk lid as it was replaced. I'm sanding clear now.
Old Oct 27, 2022 | 06:03 PM
oldolds88's Avatar
if you buy the paint in quarts,get a gallon or bigger can,mix all the quarts together,so the color will be uniform. seen guys run thru 1/2 gallon,mix another half and the color isnt the same
Old Oct 28, 2022 | 05:04 AM
Post70's Avatar
Oldolds88 has good advice and write a note on the leftover can you used the white sealer.
Old Oct 28, 2022 | 08:07 AM
Andy's Avatar
Definitely post some pics when done..love to see it, My car is one repaint lacquer, going to do some touch up on it because it’s such a survivor..I had fixed some rust on front fenders so I sent a sample out to TCP Global to use the paint code along with color match..Its not a close enough match so I just sent it back, they are going to try to get it right..I sent a couple more samples..obviously this will be in acrylic lacquer so I can blend into the current lacquer paint.
Old Oct 28, 2022 | 07:58 PM
4+4+2=10's Avatar
I will post some pics when I get it where I want it.
Depending on how old your lacquer is, you may have a very difficult time matching it for a blend out. The metallic size on old school paint was noticeably smaller than what is used in modern paints. In fact, at a distance of 2 feet you cannot even see individual flakes. In modern paints you can see individual flakes even from 5 or 6 feet away. Another difference is that the old lacquer was lead based. Modern lacquers have no lead and this affects durability.
Granted, these cars will not see the same road use these days, but these factors will complicate getting a good match.
Good luck,
tc
Old Oct 29, 2022 | 02:02 AM
Andy's Avatar
Good luck,
tc
Thanks, not overly concerned about the blend, having tcp global color match a sample..hopefully close enough to blend nicely. Car was repainted in 1987 acrylic lacquer, paint manufacturers stopped using in lead in 1978 so I should be ok on that front..
Old Nov 4, 2022 | 09:51 AM
4+4+2=10's Avatar
Here is a couple of teaser pics. This has been a drama filled experience. First was trying to get a decent match to the color that was on the car to start with. I went two places to have the paint scanned and was successful at neither. Camera malfunctions...apparently Gold metallic is hard to read. Next up was to match it with color cards. The card that was the closest was a color called "Riverside Gold"
Perhaps there is something about the way I shot the color, but this turned out too dark for my liking. This wasn't a total loss of effort however as I decided to use this as my stripe color. I sanded the whole car again with 600 / 800 paper being careful not to break past the clear. This was no small effort.
Next was to make some adjustments on the paint formula. Basically just left the small amount of black out of the equation. This was much better, but still not a perfect match to Galleon Gold. I finished shooting with what you see here at 2:00 AM this morning. I have some dirt to sand out of the clear, as my homemade booth wasn't ideal. I will post some more when I finish buffing and get the trim back on.
tc
Old Nov 4, 2022 | 10:18 AM
Post70's Avatar
Looks great, good job.
Old Nov 4, 2022 | 11:37 AM
Andy's Avatar
Looks nice, more nugget gold than galleon gold, but beautiful none the less. I sent a metal sample out to TCP global to color match my Galion Gold 70. They mix it to paint code 58 and said it was right dead on, when I got it back and spray the card out it’s not. I’ve now sent it back and they’re gonna try to fix it with more samples from metal I cut out that still had paint on it. My car was painted once in 1986 in lacquer, and it’s a little bit lighter than true Galleon gold.. so hopefully I get it back here at some point correct so I can blend it. I don’t wanna paint the whole car. The darker color is what they sent me, the lighter color is whats on the car.. as I said hopefully they can get it much closer so I can blend a couple fender patch panels I welded in And a rear outer wheel lip and outer wheel lip skin that I weld it in. The darker color they mixed I believe is correct for code 58 Galleon Gold..Howerever asked them to color match my sample and they didn’t so hopefully they’re fixing it
Old Nov 4, 2022 | 11:47 AM
Andy's Avatar
this is my car, this lacquer was shot in 1986, very very close to galleon gold, but a tiny shade lighter..which could have been gun pressure.
Old Nov 4, 2022 | 01:00 PM
4+4+2=10's Avatar
Galleon Gold is code 55. Burnished gold is 58. Your car looks closer to Burnished Gold than Galleon Gold to me.
Old Nov 4, 2022 | 01:30 PM
Andy's Avatar
You are 100% correct, the mind is the first thing to go..😌. Mine is burnished, like my brain🤣
Old Jun 11, 2023 | 03:57 PM
4+4+2=10's Avatar
I've never claimed to be fast.... 7 months after shooting the car, here it is in all of it's cut and buffed glory. (or something like that). There is an "off the rails" easter egg somewhere in these pics. When you find it, don't give it away.
Old Jun 11, 2023 | 04:38 PM
Andy's Avatar
Looks fantastic…the ghost stripes are cool. Well done brother.
Old Jun 11, 2023 | 05:00 PM
OLE442's Avatar
Looks great.
Hope mine looks this good.
I'll have to go back and re-read the complete post.
I'm still nervous about spraying metallic lacquer with a HVLP gun. I sure don't want stripes on most likely my last car.
BTW, didn't 1970's Cutlasses have the hair remover extension down in the middle of front of the hood? Did you just attach it to the grills some way!
Really sharp,
OLE442
Old Jun 11, 2023 | 05:51 PM
4+4+2=10's Avatar
Originally Posted by OLE442
Looks great.
Really sharp,
OLE442
Thanks, I was pretty nervous as well. I used a Harbor Freight Black Widow. It worked great for me. Watch some "Paint Society" videos on you tube. Base/Clear materials today allow Novice painters to work above their pay grade even in a homemade booth. I'm not sure I would have the kahunas to do a whole car in single stage metallic lacquer.
As for the the head knocker removal, I made an angled bracket and riveted it to the hood latch support and then fastened the tooth to it. It is all easily reversible with new hockey sticks. I may start a new thread on the mod someday.
Yeah, you found the Easter egg....
Old Jun 12, 2023 | 08:26 AM
ijasond's Avatar
Purveyor of Polyurethane
Looks fantastic to me. I dig the subtle stripes.
I’ve been in the paint business for 26 years and I’ve seen professional painters do worse. A lot worse.
Old Dec 25, 2023 | 09:26 AM
oletrux's Avatar
Late to the party, but I agree with all that's been said. I like the ghosting of the stripes too.
rfpowerdude
Feb 21, 2022 02:29 PM
Paul Myers
Oct 16, 2021 04:36 PM
Andy
Sep 6, 2021 05:42 PM
quaddriver
Paint
Sep 5, 2016 03:14 AM
johnnyjaws
Apr 21, 2015 12:22 PM
