epoxy primer/sealer
Old Aug 31, 2025 | 11:47 AM
Chuxter's Avatar
1970 Cutlass Supreme
epoxy primer/sealer
I just put down a layer of epoxy primer, ppg mp170, due to several factors of equipment and operator error I had several spots to sand down. I have used a 400 wet sandpaper and it is coming out ok. My question is do I need to put another layer of primer on before I put my Base coat on? TIA
Old Aug 31, 2025 | 03:14 PM
If you have sanded through to bare metal or filler, yes. In any case, what does the tech sheet for your selected topcoat say?
Old Aug 31, 2025 | 06:43 PM
Chuxter's Avatar
All I find on the tds sheet says to top coat within 72 hours. If not it must be scuffed to reapply. I'm going to wet sand the whole thing and put down 1 more coat and then the basecoat within the time frame allowed. I'm reading that will give me the best adhesion.
Old Sep 1, 2025 | 04:20 AM
It will.
Old Sep 1, 2025 | 02:44 PM
Andy's Avatar
Typically you put down epoxy primer, then bodywork, then build primer blocked down and a sealer before your top coat. It all depends on what type of finish you are looking for. Data sheet is your guide along with your paint rep.
Tedd Thompson
Paint
Aug 23, 2021 08:42 AM
Del70
May 8, 2011 09:27 AM
Del70
May 6, 2011 03:54 AM
semper-fi
Dec 20, 2009 05:12 PM
American Lead
Dec 18, 2006 05:32 PM
