door jamb paint removal
Old Mar 30, 2009 | 07:10 PM
68Tom's Avatar
I have a question. If you are using a sanding disc or stripping solution to remove paint, how can one adequately remove the paint from all the difficult areas--the door jambs, etc? I am unable to really get the sander in the tight spots, a wire wheel brush on a drill seems to be completely useless on anything but removing rust, and the paint remover doesn't get everything off the surface as it's impossible to scape in certain areas, and the remover really doesn't take off the very old primer or e-coat that was on the metal.
I'm starting to get frustrated and concerned that my surfaces aren't going to be prepped properly for paint.
Old Mar 30, 2009 | 08:08 PM
ent72olds's Avatar
Registered Luser
Tom, we stripped the jambs and "hard to reach" places on the Vista with no problems and little effort with a high speed electric drill and wire wheels. Also used 3M fibre discs(3" don't have the part # on me) on the angle die grinder. Worked fast and thorough. If you need the part #, I can get it tomorrow nite but late as I will be working.
Old Mar 31, 2009 | 04:28 AM
I was thinking of the 3M fiber discs as well. You can get the fine and coarse ones at the auto parts store or even Wal Mart. They take paint off easily.
Old Apr 9, 2009 | 06:33 PM
ijasond's Avatar
Purveyor of Polyurethane
I used a small hand held hopper type sand blaster on mine. It worked well, took a little while to clean up the media though. I would definitely choose it over a chemical stripper. Chemical strippers are a nightmare.
Old Jul 3, 2009 | 12:09 PM
Lima-Gaucho's Avatar
Hello
Another produckt from 3M is called Roloc Bristle Discs
http://www.autolackprofi.com/shop/im...ang/46433Z.jpg
you put it with an adapter on a drilling machine.
Or
you bring it to a professional who remove paint with a special kind of thinner , they put it into a dipping bath . after this in another dipping bath with phosphoric-Acid this will remove every rust and oxidation.After this it look like this parts .
Saludos Markus
Old Jul 3, 2009 | 12:14 PM
here is another close up pic from inside the fender . Every pice is bare metall without any oxydation you only have to primer it.
Old Jul 3, 2009 | 04:36 PM
ijasond's Avatar
Hopefully he has this part of the project done by now. If not, I don't think that stripping the car down to its shell & taking it to have it dipped is really a practical option to prep a couple of door jambs.
Old Jul 3, 2009 | 05:12 PM
BosMobile's Avatar
Hey,it's going to be tough with the doors on.I use a small[2 qt]sandblaster,called ''speed blaster'',most auto paint stores can get one.Got to have compressure though.
You can drill a small pilot hole in the hinges,so realining the doors is not a guessing game.I use a scribe to mark where the bolts go ,for realinment,with the doors off you should be able to get in there.It's not a fun job,good luck!I'll be glad to help if you have more questions,later,BO
Higgins
Aug 8, 2010 03:00 PM
stevengerard
Sep 29, 2009 03:17 PM
skryla
Jul 9, 2008 11:31 AM
silverriff
Mar 18, 2008 06:27 PM
71 Cutlass Convertible
Dec 10, 2004 12:18 PM
