bronze engine paint
Old Jan 12, 2016 | 09:22 AM
wisniows's Avatar
bronze engine paint
recently my engine was rebuilt and the engine was pained a bronze color from brothers, I am satisfied with the color, during the rebuilt I installed a new intake and carb but now I want to install my original intake and carburetor, I had the intake baked and it is primed and im about to paint it but the paint that I used for the engine is pealing, im not sure if I used the wrong primer, or if it is the paint, or the engine is hot and causing it to peal can someone advise me if there is a special primer that is needed I don't want to paint the intake manifold and have the same problem with the paint thank for the help
Old Jan 12, 2016 | 11:26 AM
Chesrown 67 OAI's Avatar
Get Bill Hirsch paint. you will be satisfied. 667-67 engine bronze
Old Jan 12, 2016 | 11:37 AM
CRUZN 66's Avatar
Olds Fever
X2 - BILL HIRSCH -
http://www.hirschauto.com/ENGINE-ENA...T/OLDZ%20BRZN/
Old Jan 12, 2016 | 12:21 PM
L69's Avatar
L69
X3 on hirsh. Fusicks seem to have been off the last couple years for me. I'll try and get pics for u. The fusicks appear more orange.
Old Jan 13, 2016 | 04:28 AM
Bfg's Avatar
Bfg
Try Rustoleum brand aged copper
Old Jan 13, 2016 | 04:12 PM
TK-65's Avatar
Fusick paint
Old Jan 13, 2016 | 06:34 PM
The Fusick's that I used came out mostly gold.
Old Jan 26, 2017 | 04:57 AM
wcwhite's Avatar
Has anyone used the bronze Thornton GM Restoration Paint?
Old Jun 9, 2017 | 07:19 PM
allyolds68's Avatar
Here's a pic of Rustoleum aged copper against an original 68 block. Not even close. It was a total waste of time and money. Next time I go right to Fusick. (I have four cans on the way now).
Old Jun 9, 2017 | 07:26 PM
The Aged Copper is for 66-67 Bronze - not for 68 G block. Sorry if you were misled Mike. Send en to me. LOL
Old Jun 9, 2017 | 07:38 PM
tru-blue 442's Avatar
Old School Olds
Dusty from sitting in the shop but it turned out nice. 2 cans to do a 455.
Old Jun 10, 2017 | 09:17 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
The only way to stop the paint from burning off the intake is to install the heat riser block off plugs either in the heads or in the intake. If you're interested in the whole process let me know. Yes, the car will be cold blooded but if it's a summer cruiser it's a good trade-off.
Here is a pic of my intake that was painted circa 2002
The paints from Fusick, the copper, and the air cleaner orange.
Old Jun 10, 2017 | 09:42 AM
Rocketguy's Avatar
Do you mean you had the intake hot tanked? If so that still may not have it clean enough for the primer to properly adhere. Do an adhesion test on it before you paint it; if it is holding up well at minimum scuff it up with a scotch bright before painting it.
Your peeling problem is probably not due to the paint but due to the prep job. It is extremely hard to get an (especially a used) engine clean enough for primer/paint hold up.
If you can always use catalyzed products. Most of the commercially available paint products are not.
Old Sep 21, 2017 | 08:49 AM
Bernhard's Avatar
I think paint film thickness and it's effects on heat dissipation should be considered. Unless the paint is designed to shed heat I would research the effects of film thickness on heads and the block, before I started loading up the block and heads with primer,paint,clear coat.
As film thickness increases there is a point were the film is to thick and adhesion and chip resistance is effected.
Great thread,I know when I'm at this stage I will be referring back to this thread.
Old Sep 21, 2017 | 12:17 PM
Rocketguy's Avatar
I wonder what paints are designed to shed heat?
Old Sep 21, 2017 | 01:58 PM
allyolds68's Avatar
If you google the "insulating properties of paint" you'll find that paint doesn't have squat for insulating properties.
Unless there's an air gap behind the paint it isn't going to insulate much of anything.
Old Sep 21, 2017 | 03:27 PM
therobski's Avatar
I used Bill Hirsh on the 64 F-85 build ( 67-400E) and pleased with the adhering. As mentioned cleanliness is key.
Old Sep 21, 2017 | 03:37 PM
classicmuscle442's Avatar
Engines did not get primer when new.
Old Sep 21, 2017 | 04:24 PM
therobski's Avatar
X2 no primer...another reason it could peel off
Old Sep 21, 2017 | 05:25 PM
Fill the paint gun with lacquer thinner and spray down the engine and repeat until you see zero oil/grease. Soak it. Let it dry then paint with engine paint. No primer required. The factory literally about dipped the engine in paint. We restorers take way more precaution when painting our restored engines then any factory worked ever did.
Old Sep 21, 2017 | 06:38 PM
Bernhard's Avatar
I went to the Hirsch web site and they list their paint for 65 to 69.
So the Hirsch paint color is really only a good match for 65 to 67?
http://www.hirschauto.com/AEROSOL-EN...Y/OLDZ%20BRNZ/
Old Sep 21, 2017 | 08:17 PM
Bernhard's Avatar
super cars unlimited
http://www.supercarsunlimited.com/65...nt.-d1225.aspx
Old Sep 21, 2017 | 08:19 PM
Bernhard's Avatar
Fusick
http://www.fusickautomotiveproducts....p?number=EP90S
Old Sep 21, 2017 | 08:21 PM
Bernhard's Avatar
Originally Posted by TK-65
Fusick paint
Attachment 157236
I like the look of the Fusick paint.
Old Sep 21, 2017 | 09:00 PM
69442murph's Avatar
i have been using white epoxy primer (dp90?) for about 20 years on my engines, and have had excellent results and top coating it with bronze that I have had mixed. If I could load pics, i would post them, but our internet connection is still running on 1970 's connectivity!
Old Sep 22, 2017 | 07:57 AM
Bernhard's Avatar
For the 69 G block who do you think has the best color match out of a spray can?
You can't beat automotive grade paint and custom color match for quality results.
Its funny I never thought about using automotive grade paint on a engine blocks even when I was in the trade.
I seen it done on show cars but never considered it for one of my builds.
Thanks for the post I'm going to consider this route for my build as well.
Old Sep 23, 2017 | 08:15 AM
Brad J.'s Avatar
I spray epoxy on all my engines as soon as I get them back from the machine shop. This seals the pores so the assembly process doesn't soak a bunch of oil into it. I mask the block and heads and everything else and shoot all apart.
I assemble the engine. Scotchbright the engine, wash with a wax and grease remover. First wash is with solvent w&g remover and then I use waterborne on the final clean. A light coat of epoxy mixed with urethane reducer for a sealer. Spray it and let it sit an hour and then I shoot the final paint.
You shouldn't use laquer thinner for a cleaner as it leaves a residue. Especially the cheap stuff that has been recycled like we buy now. Who knows what else is mixed into it.
I have a qt of Hirsch and a spray bomb of Fusick if anyone wants them. I only used enough for some sprayouts. I'm near Lansing if somebody wants to pick them up. I'm not going to ship it though. I'll never use and it and they are fresh stock from this summer.
Old Sep 23, 2017 | 08:49 AM
Bernhard's Avatar
Thanks for posting your procedure.
The engine turned out real nice, its not surprising given the detail and prep level.
What brand of voc solvent Wax and grease remover are you using?
Tumbler was what we used back in the 80's and 90's.
Also what brand of water base wax and grease remover are you using for your final wash.
Old Sep 23, 2017 | 10:16 AM
Brad J.'s Avatar
SPI (Southern Polyurethanes)
710 w&g remover
700 waterborne w&g remover
The solvent 710 cuts grease better than waterborne but the waterborne really cleans the metal better than the solvent based. That is why I use both.
flatlander442
Paint
Jan 6, 2016 10:41 AM
kelly bakies
Nov 23, 2014 01:41 PM
vistaride
Oct 29, 2012 07:36 PM
vistaride
Oct 23, 2012 05:46 PM
dan1s
Oct 1, 2008 05:30 AM
