68 442 underside of the hood paint?
Old Jan 12, 2023 | 05:26 PM
ben442's Avatar
What was the correct paint finish on the underside of a 68 442 hood? Body color, Black...? Will be swapping engines in the spring and want to refinsih the hood while its off. Thanks...
Old Jan 15, 2023 | 01:31 AM
Ozzie's Avatar
My '65 442 had satin black.
Old Jan 15, 2023 | 08:28 AM
rcorrigan5's Avatar
Randy C.
My '68 (Lansing car) was black, a satin to semi-flat kind of finish. The same for my '69 (Fremont car).
Randy C.
Old Jan 15, 2023 | 10:21 AM
ben442's Avatar
Thank, Mine is also satin black but it looks like it needs to be re-sprayed.
Old Jan 15, 2023 | 10:25 AM
Isn't it GM Chassis Black?
Old Jan 18, 2023 | 06:46 AM
68442's Avatar
Black, but if you want it assembly line correct the front portion would have body color overspray
Old Jan 19, 2023 | 05:48 AM
ijasond's Avatar
Purveyor of Polyurethane
Not painting under the hood is one of the many shortcuts gm did to save money. Most of us doing a quality paint job will paint that as well like it should’ve been, however if originality is what you’re after, put some chassis black or matte black on it and let it get overspray along the edges like gm did.
GM’s failure to paint under the hood is also why there’s often surface rust under there.
Old Jun 10, 2024 | 08:04 AM
ben442's Avatar
clean up begins...
KCastl03
Body work
Mar 9, 2022 09:41 AM
Andy
Jan 12, 2020 05:18 PM
sea442
Sep 9, 2015 04:22 PM
Jolly Green
Jul 17, 2014 11:39 PM
jensenracing77
Sep 24, 2009 09:55 AM
