1965 cutlass dash paint
I'm repainting the dash on my 65 Cutlass. The color is two shades of black, upper is flat black and lower is gloss black. I also want to freshen up the A pillers. That color is like an off white. What would be a close match to these colors in a rattle can?
Check with TK65 he just did or still is doing a correct restoration and would most likely know the answer
I'm looking to do the same thing on my 71.
A lot of the teamchevelle forum guys are saying to use SEM Trim Paint or a laquer based gloss/semi-gloss depending on how you want the finish. According to what I've read, DO NOT use an enamel based paint. Luckily everything I need is black, so not too hard to find.
If I can't find it here, I'll usually google search whatever I'm looking for with the keyword "chevelle" since you get more links than with "cutlass" haha.
http://www.chevelles.com/forums/showthread.php?t=341035
http://www.chevelles.com/forums/showthread.php?t=375422
jensenracing77
Paint
Sep 10, 2014 02:33 PM
JpMotorsports
May 15, 2014 07:08 AM
