BiG servopump leakage problem
Bought a servopump from rockauto for about maybe 1 yr ago, use it on my sbo and no problem,,
installed it on my bbo when engine swap, i couldnt understand why it was dripping and dripping, so confused where it came from. Checked all the hooses and that pipe that goes inside with the nut.
Today i finally found where it was, a crack under the paper tape rear of the pump, looks like it have a cut damage there, how could this happend? Its not even paint over it.. Looks like it was hided under the tape.
I have not done anything.. Looks like ut have broken up with the time.
Well i think i can fix this width some welding.... I think only welding will be sucsesfull cause i guess its some pressure around the system? not sure if i can block it width some engine crack stuff or sement or something....
Looked at my old pump on same place an it looks like its a little thin metal in that part.
Time to get out the pump again.. Bah...
