Useful Idea for somebody Maybe?
Old Nov 5, 2008 | 11:18 AM
lshlsh2's Avatar
71 cutlass convertible
Needed to siphon the gas out of my cutlass. I made a tank siphon from a kerosene siphon a piece of 3/4 plastic tubing that slides up and makes the siphon pick-up longer total cost for me $4.68. Got it all at a local hardware store. Hope someone else will find useful.
Larry H
Old Nov 5, 2008 | 02:04 PM
Thanks for the info. If you have a pic can you post it. I will need a siphon to change the transmission fluid in my automatic transaxle in my VW Beetle.
Old Nov 5, 2008 | 03:34 PM
lshlsh2's Avatar
Try to do in a day or two
Old Nov 5, 2008 | 03:51 PM
gearheads78's Avatar
car guy
If you have access to compressed air the easiest way to siphon anything is get a small hose 5/16 or 3/8 works perfect.Put the hose down in whatever you want to suck out. Make sure the end of the hose outlet is below the level of the fluid and blow air across the outlet of the hose. It will start the fluid just like you sucked it out with a pump.
Old Nov 5, 2008 | 06:07 PM
Oldsguy's Avatar
Past Administrator
That's a good one.
Old Nov 6, 2008 | 06:06 AM
Our friends shouldn't forget that it is a bad idea to blow air across the outlet of the hose with your mouth. This would cause gasoline, transmission fluid, power steering fluid, etc. to come pouring out all over their face. Please use the compressed air to blow air across the outlet.
dynamic63
Apr 19, 2014 09:46 AM
cutlasssupreme71
Wheels and Tires
Dec 2, 2009 02:31 PM
The_Jeremiah
Oct 23, 2007 12:32 PM
<Felipe in Brazil>
Jan 2, 2004 05:20 PM
