POA valve testing and calibration
Old Jun 21, 2014 | 06:46 AM
Macadoo's Avatar
A few of us were looking for this info a while back. Seems legit.
http://www.autoacforum.com/messagevi...threadid=16311
Old Jun 21, 2014 | 07:41 AM
Macadoo's Avatar
On further inspection, this seems to be a different POA valve. My bad.
Old Jun 21, 2014 | 07:45 AM
Nope, that's the right one, the valve just looks different without its outer case.
Here's the other thread that I've found with significant information on this subject.
There are other bits of information out there, but these two threads seems to have everything important in one place (okay, two places).
Old Jun 21, 2014 | 07:49 AM
Macadoo's Avatar
But I'm not seeing a screw with a locknut. Just something that looks like a very small nut. I'll check out the other thread. Thanks Eric.
Old Jun 21, 2014 | 08:03 AM
brown7373's Avatar
So you connect everything and it reads 28-32 for R12. Then turn the screw 1/4 turn CCW. That's it? No reading for the new pressure? Seems there ought to be a target pressure when set for 134A, not just 1/4 turn.
Old Jun 21, 2014 | 08:14 AM
The screw and locknut are inside the valve, deep in the hole.
If you look at this picture, you can see he has a breaker bar and long extension sticking out of where the adjuster screw is:
(Incidentally, this picture shows how to check the valve without removing it from the car).
Old Jun 21, 2014 | 08:15 AM
Macadoo's Avatar
This is what I see....
[IMG][/IMG]
And in the diagram I don't see anything that would be a screw. But it does look like if I turn that nut ccw it would release pressure on the bellows.
[IMG][/IMG]
Old Jun 21, 2014 | 08:19 AM
Macadoo's Avatar
Oh, deeper in there. Mmmkay.
Old Jun 21, 2014 | 08:20 AM
Read the third post in the thread that I posted after yours:
Open the high side and listen to the POA go "pop". the low side handwheel is closed and stays closed. Read the pressure on the low gauge. Should be 26 for 134a and 29 for r 12.
R12 is 29psi, R134 is 26psi.
That's why I said that thread was the other useful one.
Old Jun 21, 2014 | 08:22 AM
[IMG][/IMG]
Ahhhhhhh... Methinks you have one of the non-adjustable ones.
Apparently there are more non-adjustable valves on later cars, but it's really kinda random.
Maybe time for a junkyard run....
Old Jun 21, 2014 | 08:26 AM
Macadoo's Avatar
I have to be honest, I don't have a setup for testing. I just want to get to the screw that turns 1/4 turn ccw
Old Jun 21, 2014 | 08:27 AM
Macadoo's Avatar
Hmm, that might be why the CSM says the valve is non-repairable and non-adjustable.
Old Jun 21, 2014 | 08:37 AM
Chineseium gauge sets are cheap, and should be good enough for occasional use.
In your case, an old R12 set may be available very cheaply at a flea market or yard sale.
They're very good to have.
Cursed CSM!
Old Jun 21, 2014 | 11:52 AM
banny's Avatar
That valve is adjustable also. I would be more concerned about the rust you see down in there.
Old Jun 21, 2014 | 12:01 PM
banny's Avatar
Just remembered the replacements were also adjustable but a pita because you cant calibrate it with the air and gauges attached like you can with the originals
Old Jun 22, 2014 | 01:45 PM
Lady72nRob71's Avatar
You just turn the nut - that is what I did.
26psi is a good target for 134a.
One of these years I will get my AC system finished...
Old Jun 22, 2014 | 03:33 PM
Macadoo's Avatar
1/4 turn then?
Old Jun 22, 2014 | 03:51 PM
Macadoo's Avatar
I keep checking....
Old Jun 22, 2014 | 04:25 PM
1/4 turn then?
1/4 to 1/2 turn CCW for a guestimate.
It would be best if you could rig up a test set like in the picture.
More info on testing can be found here:
https://classicoldsmobile.com/forums...2-cutlass.html
Old Jun 22, 2014 | 05:50 PM
Macadoo's Avatar
Well we all know MAW. I'm introducing a new one; GEFN (good enough for now)
I'll start with a 1/4 turn. I'm guessing it would be better than nothing.
toymobile
Aug 5, 2015 04:10 PM
hullinger
Sep 27, 2014 05:22 PM
1970-W30
Aug 14, 2013 07:52 PM
Silchad
Sep 12, 2012 09:38 AM
Al Graaf
Apr 6, 2012 08:46 PM
