A/C Help
Old Nov 4, 2007 | 09:53 PM
sama87's Avatar
Exclamation A/C Help
I have a 1985 Toronado. Neither the AC or Heat works. If I set it to vent, I'll get a little bit of air, alot from the middle-bottom vent(sometimes). On any other setting there is no air at all. If on anything other than vent, I hear pressure escaping from the control box. Anyone know what the problem could be?
Old Nov 5, 2007 | 04:45 AM
ozoneblue's Avatar
Check for vacuum leaks from engine area to controls at dash
Old Nov 5, 2007 | 07:05 AM
Redog's Avatar
ANy ducts disconnected?
Old Nov 5, 2007 | 10:34 AM
kevinkpk's Avatar
I had a problem with a 70 delta 88, first the heater didn't work because the vacuum line was plugged off. I didn't have any vent because there is a vacuum diaphram valve that opened the flapper inside the plenuim that due to age had fallen apart.
Old Nov 6, 2007 | 08:08 PM
Jerry Weitz's Avatar
Sounds like your problem is with the mode door which determines where the air will be directed (defr, htr, ac outlets, vent, etc). Some model have the mode door diaphragm open or closed with vacuum or the opposite of being spring lodaded and open or closed without vaccum. Probably a hand vaccuum tester to determine if the door is working and a vacuum diagram would be helpful which is usually printed in the Olds shop manual or thru MOTOR manuals or Chilton or Mitchell.
Good luck
Jerry
Old Nov 7, 2007 | 06:52 AM
PS you might be able to get a vacuum diagram thru MOTOR.com...they are suppliers for ALLDATA and their data base goes back to 1982. If no luck on the internet then go to a nearby shop of which most have Motor/Alldata, Alldata or Mitchell on their PC and you can probably get a printout of the diagram for a nominal or no fee.
Good Luck
nolabigdawg
Nov 16, 2014 06:45 PM
MJAKS462
Apr 15, 2010 02:34 PM
silverriff
Mar 24, 2010 06:36 PM
martine
Jan 22, 2009 01:13 PM
ToronadoGuyDenver
Brakes/Hydraulic Systems
Mar 18, 2007 02:52 AM
