ISO Floorboard Clips??? Not sure what they would be called.
Old Sep 24, 2019 | 07:37 PM
Tjohn8573's Avatar
Looking for four of these clips??? They are used to hold down wires to the floorboard. Anyone have any? Appreciate it! Thanks!
Old Sep 25, 2019 | 05:54 AM
I believe those are spot welded to the floor. Probably need to cut some out of a junk car
Old Sep 25, 2019 | 06:00 AM
Tjohn8573's Avatar
No these ones are screwed to the floor. They on the passenger side not the drivers side. I think they are only used for Routing wires for things like power antenna, rear speaker, rear defrost, and trunk release.
Old May 10, 2020 | 11:32 AM
rocketscientis's Avatar
Potatoe - Poetato...
Tabs , retainers
have you located some ?
Old May 10, 2020 | 04:00 PM
Tjohn8573's Avatar
Originally Posted by rocketscientis
Tabs , retainers
No I have not found any?
Old May 10, 2020 | 04:10 PM
2blu442's Avatar
I'm also used to seeing those welded to the floorboard. What car are you working on?
Old May 11, 2020 | 07:07 AM
Tjohn8573's Avatar
it is a 1968 Cutlass. The Regular ones on the drivers side are welded to the floorboard. These are the ones in the Passenger side of the car. They screw down to the floorboard. Used for running accessories under the carpeting to the rear of the car such as the trunk release rear speaker and rear power antenna.
richeyb
Oct 10, 2025 11:27 AM
Doug Blake
Feb 7, 2018 05:34 PM
Rocket331
Body work
Sep 18, 2012 04:00 PM
golds56
Mar 1, 2012 12:24 PM
budsisto
May 19, 2011 02:50 AM
