Windshield wipers & Washer?
I'm not sure how the wipers are suppose to rest. See the pics... Are the wipers suppose to stop above or on the chrome? Also, is this a hood or wiper issue - wipers hit the hood? Are the wipers suppose to set below the hood?
Finally, what is the correct washer set-up as mine is not connected?
Thanks!
Thanks!
Do you have the rear rubber bumper in place in the center of the cowl screen? The original wiper arms took rubber refills & I believe they are not as tall as your current set up. You have what is called the "hidden wiper system" & the wipers are supposed to park about half way down on that stainless piece with out hitting the hood. Under the cowl screen on the driver side there are 2 nuts & studs that provide some adjustment to where the wipers park. With your hood up, do the wipers park farther down? If not, you may need to adjust them. Report back with more info.
I'm thinking I need new wipers, these are too tall. Is this a special item?
The original wiper arms took rubber refills and reused the arms. I have several sets of those if you need some. I'm not sure how easy it is to get the rubber refills anymore. There may be some newer wipers like you have on your car now but that are a bit shorter and that may not hit the hood? Might have to remove one of yours and go to the parts store to compare.
