Inner door part. Where does it go?
Old June 14th, 2017, 04:10 PM
Powerm01's Avatar
Hello all,
First of all I would like to say what a great asset this website is. This page has helped me so many times.
Now to get to the nuts and bolts!!!
I took a part my door to paint it and now I seem to have one extra part!!! Where does this thing go? My I get a pic, diagram, something😝
Powerm01 is offline
Old June 14th, 2017, 07:26 PM
Tedd Thompson's Avatar
Ah, what year and model?
Tedd Thompson is offline
Old June 14th, 2017, 07:33 PM
Gary M's Avatar
Pretty sure that stops the window from going up too far.
Gary M is offline
Old June 14th, 2017, 07:46 PM
Olds Fever
CRUZN 66's Avatar
Could be a down stop as well...
CRUZN 66 is offline
Old June 14th, 2017, 07:59 PM
Powerm01's Avatar
1971 Cutlass Supreme
Powerm01 is offline
Old June 14th, 2017, 08:11 PM
steverw's Avatar
Definately a window stop, check the other door since you only have one left over? There should be one just like it in the other door, see where it is.
steverw is offline
Old June 14th, 2017, 09:07 PM
Powerm01's Avatar
Yeah, No I have two. One from each door
Powerm01 is offline
Old June 14th, 2017, 09:22 PM
Powerm01's Avatar
Ok did some googling. Pretty sure according to Opgi it might be the
1970-72 Chevelle Hardware, Side Glass Door Window Glass Up Stop, Rear
of course for mine it's for the cutlass. Now I just need to figure out where to install
Powerm01 is offline
Old June 15th, 2017, 01:24 PM
Gary M's Avatar
It's going to go back near the lock **** area and as you roll up the window you will see the part mounted on the window mechanism that hits your bracket. If you have not gotten it before tonight when I get home I will post a picture for you. Could not get to it yesterday.
Gary M is offline
Old June 15th, 2017, 03:10 PM
Gary M's Avatar
It's not in my book but on my 72 it looks like they bolt to the window mechanism at the bottom and go up and down with the window. One in front one in back.
Gary M is offline
Old June 15th, 2017, 03:18 PM
Gary M's Avatar
My weatherstrip is not installed so that's how I got this shot
Gary M is offline
Old June 16th, 2017, 01:37 AM
Powerm01's Avatar
I see. Thank u very much. My body guy already installed my weather strip. 😝He is in a hurry. Body panel is not installed so hopefully we can still install it with out taking the stripping off.
Powerm01 is offline
Old June 16th, 2017, 04:54 AM
Gary M's Avatar
door panel off is fine. Weatherstrip will not be affected or in the way. Good luck.
Gary M is offline
Old June 16th, 2017, 07:35 PM
Yellowstatue's Avatar
You should have two extra bolts and washers too.
Yellowstatue is offline
Old June 20th, 2017, 08:10 AM
Powerm01's Avatar
Yeah!!! Got it fixed. Thanks guys!!
Powerm01 is offline
costpenn
August 29th, 2018 11:42 AM
70 w-30
January 28th, 2017 06:52 PM
LJ72Cut
March 14th, 2016 09:19 AM
jensenracing77
December 9th, 2013 02:12 PM
davebw31
March 25th, 2011 06:55 AM
Quick Reply: Inner door part. Where does it go?
