Aftermarket gauges
Old January 25th, 2017, 09:18 AM
1970Ragtop's Avatar
Aftermarket gauges
I am looking to put in an under dash temp and oil gauges in my 1970 Olds cutlass convertible. Do anyone know if they make a gauge that flips up to hide when it is at the car shows. I had it overheat when I was at the Back to the bricks in Flint Mi car cruise. Thank you for any info.
1970Ragtop is offline
Old January 25th, 2017, 11:09 AM
I haven't seen any gauges like that. I have mine mounted to the bottom of the dash, above the console, and leave them visible.
If you don't have an 8 track player, you could get one of the converted housings that hold gauges and it would look a lot like a factory setup.
Fun71 is offline
Old January 25th, 2017, 11:12 AM
gbledsoe3's Avatar
You could change them all with something like this from Dakota Digital.
gbledsoe3 is offline
Old January 25th, 2017, 11:29 AM
D. Yaros's Avatar
I suspect that what you seek is not available. While I can see crafting a gauge panel having flip up/down capabilities, there would be a problem with the water temp probe and oil pressure lines used on mechanical gauges. Maybe that could be gotten around by use of electrical gauges? I don't know much about them.
D. Yaros is offline
Old January 26th, 2017, 10:28 AM
Smash
smash72's Avatar
Mount whatever mounting they come in on a small piano hinge should be fairly easy to do.
smash72 is offline
Old January 26th, 2017, 10:50 AM
delete
droptopron's Avatar
Get 2" gauges and mount them in the ash tray
droptopron is offline
Old January 26th, 2017, 12:06 PM
I'm sorry, but why are any of these suggestions better than just installing a repro Rally Pac?
joe_padavano is offline
jpc647
December 22nd, 2009 06:05 AM
citcapp
December 14th, 2009 11:10 AM
car_designer
March 9th, 2009 07:56 AM
ct1979
January 9th, 2007 09:17 PM
skibone
April 15th, 2004 03:13 AM
Quick Reply: Aftermarket gauges
