The "GM5.0L" is all you need to know. Do the math. 5.0 liters is a 307. I can't clearly make out the VIN derivative stamp, but if that's a "3F9xxxxxx" then the "F" indicates the 1985 model year and the "9" would be Oshawa assembly plant. Which heads are on the motor?
